Root [Revised] Rooting Gingerbread 2.3.5 Dummies Guide
Well, it was all java issue. for some reason Chrome was blocking java. I tried Firefox and voila. :D I am unlocked.
Unfortunately, it did factory reset! So all my apps and contacts etc are wiped out. No big problem. I can recover the contacts - already did with google sync. I can always get the apps back.
Thanks for the posts
Everything seems to be going well until I get to the cmd prompt and type in the get identifier command...instead of getting Identifier Token Start listing to copy it just says 'waiting for device'...any solutions?
NICE!!!!!!!glad it worked for you.
is your phone set as charge only or do you have is as disk drive? make sure that it is charge only. also make sure nothing like pda net or anything that can communicate withe your phone. they might interrupt the process.
According to the directions at that point my phone should be plugged in and I'm at the fastboot menu and it doesn't have an option for the type of connection. When I plug it in though windows tries to look for the driver for the phone...could that be the hang up? (the options say that the device will not function correctly without the driver 1.0)...how do get around this?
do you have htc sync installed? in the op there is a link for it there. try installing and try again.
HELP!! PLEASE???
I think I just bricked my wives phone. I had followed the instructions set forth in this thread to root her phone. I had successfully made it to the point of using Android Flash so that I could use Amon Ra and one of the kids grabbed her phone off of the computer. It had not completed the flash, and now it will not boot up at all. I was S-off and not watermarked, if that helps. Thanks in advance for any help.
HELP!! PLEASE???
Do you still have recovery? Can you get to the hboot screen?
When I last post I could not get ANYTHING to boot. Nothing at all. I got the screen with the phone and a RED triangle. So I let it sit while I went out for a ride to relax from the frustration. Now the phone will load normal and I can get to the hboot screen. So I am going to go back through the directions (since the issue was kids and operator error) and start over.
This is what I got after attempting via method #1. Not Android Flash
C:\android>fastboot flash recovery recovery.img
sending 'recovery' (3544 KB)...
OKAY [ 1.078s]
writing 'recovery'...
FAILED (remote: not allowed)
finished. total time: 1.080s
OKAY [ 1.078s]
ok so i'm confused you said you have s-off now with no watermark. did you follow captian's guide? i'm not sure where you are at in the rooting process.
what is your hboot?
HBOOT 2.10.0001
after doing some reading I think what happened is that for some reason I have lost root. When I start the HBOOT it finds the PC36IMG file and asks if I want to start the update? I choose yes, and let the file load. After the update is complete I choose no for the reboot so I can go into recovery. Only problem is, there is no recovery. Which is why I think I have lost root and will re-run Unrevoked tomorrow. I think that should solve my issue.
Thank you for your great instructions. If I would have read them a little better to begin with, I would not have had to bother you with my issues.
HBOOT 2.10.0001
ok if you have s-on and hboot 2.10 then yes try and re-run unrevoked.
I made the mistake of doing the 2.3.5 update. I am new to all this. My question is when creating the android folder, is this folder being created on pc or on phone sd card? I am assuming on pc.
welcome to the forums!!!!!!!!!!
all of this will be on your pc. you really do not do much on the phone until you get to the part after you unlock the bootloader.
Ok, what if I have HBOOT 2.10 and S-OFF? Should I re-run unrevoked, or try something else?
:confused:
if you have s-off but no recovery then all you need to do is install a recovery via a PC36IMG file and have the bootloader install it for you. no need to run unrevoked as you already have s-off.
go to the http://androidforums.com/evo-4g-all...ooting-dummies-guide-gingerbread-edition.html and go to the switching recoveries section in the guide. it has a step by step process on how to get recovery onto your phone.
once you have recovery you can then flash a rom like mikg3.0 (which is amazing) and you are good to go.
any questions let us know.
Some how, some way the PC36IMG that I had downloaded was empty. Not sure what the heck I did, but I found an img that worked and now Im back in business. Thanks for your help OCN!!:D
Been reading off this site for the last week, prepping for my root and getting ready. Love the info here!
Having issues with the Superuser though (not after other ROMs at present, just trying to clear off these 'bloat' apps from Sprint)
Followed HTCdev site instructions successfully, then placed the Superuser on root of SD card and flashed, then rebooted.
Superuser app is now on the phone but it doesn't any of the stock apps (Nascar, Kindle, etc) for me to delete.
Something simple I missed?
You have to install a program from the Market (Titanium Backup, for example), that allows you to uninstall system apps. That's how you get rid of the bloat.
Hi, I went to the HTCdev website. I followed the directions, but its telling me to open these files and I can't find them anywhere on my laptop. I have never done anything like this before and I have no one to help me. If you can it would be greatly appreciated!
Open what files? The more details you give us, the easier it'll be to help. At what point are you in the process? The more details, the better :).
The farthest I have gotten is step 5 lol. i have my phone hooked up to my laptop now, and i've created a new folder but i'm not sure where to go from there. it tells me to find the 3 files and i cannot. the files are
  • adb.exe
  • AdbWinApi.dll
  • fastboot.exe
my phone isn't even showing up on my laptop, and when i hit fastboot like it says to it scans and says that it cant find this file: PC36IMG
I noticed somewhere that someone had said to download it, but I have no idea where. I feel like a complete idiot, and i have read this whole thread multiple times and I'm still not getting it.
  • adb.exe
  • AdbWinApi.dll
  • fastboot.exe
Did you already download the Android SDK? That's where those files come from. That's one of the things you have to install per "the setup" section of the guide.
In fact, did you download and install any of those items? HTC Sync is what allows your computer to recognize your device when connected. I think you might want to start over and make sure you have everything downloaded and installed. When you have all the files and drivers you need, the instructions should make more sense.
EDIT - From OP:
the setup
you will need to download these files:
Android SDK
HTC Sync 3.0.5551
Java Runtime Environment (JRE)
