Root Revolutionary.io gone???
freeop
Member
Just got started trying to root my EVO 4G and got to the part where I am supposed to get the Beta Key from revolutionary.io, but the page is not coming up. Did they block or take it down? I ran the revolutionary.exe and am at the point where I need to enter the beta key, but can't get any farther.
Anyone have any idea about revolutionary.io?
I guess the site is being overwhelmed by requests, will just have to wait, I guess.
yeah i cant bring it up either. site must be down. i think you guys blew their server up or something.
Thanks for the conformation, ocnbrze. In the middle of your guide and stuck at that point now. Will just have to wait, :)
Is there anywhere else you can obtain a beta key? This has been going on for over an hour now. Like you said, maybe their server is down. I guess just have to wait in see...
Downloaded all files and opened up revolutionary but the dos window just keeps saying waiting for device. I cant input my beta key!!! Ive been reading the WHOLE thread all morning and seen other posters had the same problem but cant figure out what to do next. Turned off Microsoft security essentials,rest phone,charge only,debugging turned on......
2.3.3
2.15.00.05.02
2.6.35.10-gc0a661b
htc-kernal@and18-2 #1
Tue Jun 14 23:58:32 CST 2011
4.24.651.1 CL61076 release-keys
4.24.651.1
Web/Kit533.1
2.15_003
60680
2.3.3
2.15.00.05.02
2.6.35.10-gc0a661b
4.24.651.1
Web/Kit533.1
2.15_003
60680
not sure it seems that sometimes revolutionary has trouble communicating with the phone. try and do a factory reset on your phone. also i would copy your card to the computer and reformat it through your phone and try again.
ok do i need to install hboot drivers? This is my first android device and my first time rooting. Im pretty tech savy but new to this so bear with me. I wont ask any unnecessary questions. thx... I also tried to hold the power and volume down button to get into hboot but it just turns the phone back on.
2.3.3
2.15.00.05.02
2.6.35.10-gc0a661b
4.24.651.1
Web/Kit533.1
2.15_003
60680
Make sure all antivirus are off. It interrupts the whole process.
the only drivers you will need is the fastboot drivers that is provided on the guide. if you have any drivers like that uninstall them. same goes for htc sync.
as far as the hboot goes you need to turn off fast boot (phone settings/applications/uncheck fastboot). now you should be able to get to hboot. and no question is stupid. feel free to ask it here in this forum.
Take out battery, then reinsert it and then try what you have been doing.
thx fellas I just bought this phone off of craigslist and its in really good condition Ive look and dont see htc sync anywhere on the phone plus I already factory reset it I just though i might need the hboot usb drivers
I finally got it rooted :eek: I dont know what the exact problem was but im not complaining thx to everyone that contributed to this update
