I finally got to sit down and try to root my EVO,but the Revolutionary.io file wont come up when I click on the link. It wont send to the website. Anyone else having this problem?Please help.
Thanks to all that reply
I will post when I can get into the website
revolutionary is up.
Im sorry,but been checking and still not able to get in.
I was able to turn my S-OFF. Do I have to run the Flash ClockworkMod in the DOS area to make it work. I didnt do it the first time and was able to see I had the S-OFF, but it wont load the fastboot. JUst keep getting the red triangle. Any help please.
Thanks to all that have helped out
1. you can run revolutionary again to get clockwork mod recovery.
If he is a noob like I am, I answered no to install clockworkmod the first time because I didn't realize what it was for. Could you add that to your sticky?
I got the same screen the first time, ran through it again, installed clockworkmod and was good to go.
I'm pretty sure it is right after the revolutionary tool runs for S-OFF and comes back to ask you if you want to download CWM and install (y/n)?sure i just not sure when it asks you to to do it. did it asks you the first time? or is it just the second time around. i'm not sure as i have not done this myself.
The second time if you run it again, it will tell you that you already have S-OFF and ask the question again.
when it asks you for clockwork mod and you said no, where does it take you to?
I have a bad memory, but I'm pretty sure the bootloader comes up, I chose recovery just like the guide says. That's when it will give you the dreaded triangle with exclamation mark.but when you said no. does it take you to the bootloader?
You need the cracked hotspot that roms include. You can try the Wifi Tether in the market though. That one works too.I got 1 more question. I got it to the S-OFF and I was able to run the (superuser su-2.3.6.3-efgh-signed.zip file and said I was good. I did this to use the HOT SPOT for free. I turned on the HOTSPOT it says the HOTSPOT is active on the top and then it tells me I my account does not include Mobile hotspot service. Did I do it worng or it will says this anyways and it isnt detected by sprint. Please HELP ME!!!
