RevolutionHD problems
showmestuff-S2
i got the new ki4 rev rom zip on my phone
went to rom manager tried to install it got the signature failed message
what do i have to do to get it on ki4
im on ki3
siyah
rev rom
I've had loads of problems getting things to flash when using the siyah kernels. Your best bet is probably to flash a cfroot kernel with odin. Then you should be able to instal the rom.
i nmanaged to get it on
now im
ki4
ki4
checkrom rev
i dont know why i must meddle with things
the old saying rings so true if its not broke...
brake it
if i choose a theme in kitchen and apply it
the icon shows a memory card icon so i pressume its saved on phone
how can i apply these without booting the phone everytime
once you've applied an item from the kitchen, you should get a pop-up box asking you to install. it will reboot every time.
you can "mark for installation" multiple items before clicking apply, this will only reboot your phone once but apply everything.
re not on rev rom, is your kitchen using the right server? menu>more>settings>select server - make sure checkrom server selected.
Some people on xda are reporting problems with the kitchen.
Are you using version 1.2.2?
Did you do a full wipe including factory reset before installing?
Also I read somewhere that before installing check rom that best to remove kitchen app and all it's files first. Did you do this?
brake it
if you will forgive me for saying so, another axiom comes to mind...
"A little knowledge is a dangerous thing" :D
i dont know which version im using
i didnt do a full wipe ir fac reset
or remove kitchen lol
Not very good with instructions either are we showmestuff-S2? :D
The instructions for installing the ROM clearly state:-
Q: I'm coming from a different ROM how can i install this ROM ?
A: Follow the steps below
Get into the CWM recovery
Wipe Data/factory reset
Wipe Cache
Wipe Dalvik-Cache
Wipe Battery Stats
Wipe Cache
Wipe Dalvik-Cache
Wipe Battery Stats
Install the wipe version of this ROM
in this post on installing:-
xda-developers - View Single Post - [ROM][XXKI4] Leo & Check's CheckROM RevolutionHD V1.0 |NEW KITCHEN PRO APP|
I would advise you to start from the beginning again and this time read and follow the intructions carefully.
Step 1. should be to ensure that you are properly rooted and have a working CWM, BusyBox and Titanium Backup Pro installed and then go back to the Revolution Rom and start from scratch.
Don't worry... you'll get there. :)
i follow instructions bad
im downloadin rom from kitchen n see how that goes
next step i will follow instructions but lemme justt see
I think the problem is with CWM v5.0.2.6 in Siyah, it doesn't like auto flashing tools like the Kitchen, if you install an earlier version of CWM like v4.* then it should be ok.. or change to a kernel that uses that version.
Yeah I had a few problems with siyah 2, but 2.1 has sorted the problem, things now flash from the kitchen without any worries.
my phone has been going mental saying hdmi connected then games were starting on there own
so i Wiped Data/factory reset
Wiped Cache
Wiped Dalvik-Cache
Wiped Battery Stats
Wiped Cache
Wiped Dalvik-Cache
Wiped Battery Stats
then rebooted but now my phone is stuck on the boot animation i waited for about ten minutes then popped the battery out
i didnt think it would turn back on but it did and thats where i am now
help plz
