danielunde Android Enthusiast Jul 23, 2012 #1 Whats the best way to install and can i delete ring tones in the root? in this ringtone pack there's two of the same ring tones/alarms?
Fuzzy13 Extreme Android User Jul 23, 2012 #2 Ringtones are located in system/media /ringtones Just paste whatever ones you want in that folder and reboot. You can also delete ones you don't use. Then reboot.
