I screwed up my S2 when testing different ROM:s
Now it is dead ... can't power it on - only download mode works.
I tried to install the original Samsung ROM ... but it didn't work.
Is there a way to kick it alive ?
The fact that download mode works on your phone says the problem flashing the stock firmware is coming from your pc. Make sure you have the correct usb drivers. Make sure kies isn't running as this can interfere. A reboot of the pc can make sure. If not try a different usb hub or if possible a different cable
