Help Roaming?
So my 3G stopped working today randomly, so I started trying to figure out the cause. I plugged it into my pc, rebooted my phone and started logcating. I let it fully boot while looking for errors and there were none. I started to toggle my 3G on and off while logcat was running and that's when I came across this error:
D/PhoneApp( 1554): mReceiver: ACTION_ANY_DATA_CONNECTION_STATE_CHANGED
D/PhoneApp( 1554): - state: DISCONNECTED
D/PhoneApp( 1554): - reason: radioTechnologyChanged
D/NotificationMgr( 1554): hideDataDisconnectedRoaming()...
E/DataSettingButton( 1541): onReceive()-S:
D/ConnectivityService( 1197): getMobileDataEnabled returning false
I/MediaUploader( 1971): No need to wake up
E/OggExtractor( 123): mGranulePosition - ERROR_OUT_OF_RANGE
I/BitMapFactory( 1197): BitmapFactory: NOT A DRM File , So no Need to load DRM Library unnecessarily !!
D/ConnectivityService( 1197): reportNetworkCondition(0, 0)
D/ConnectivityService( 1197): Inet connectivity change, net=0, condition=0,mActiveDefaultNetwork=-1
D/ConnectivityService( 1197): no active default network - aborting
Does this mean my phone was trying to roam?
Edit: Ran logcat while togeling airplane mode and got this:
D/PhoneApp( 964): mReceiver: ACTION_ANY_DATA_CONNECTION_STATE_CHANGED
D/PhoneApp( 964): - state: DISCONNECTED
D/PhoneApp( 964): - reason: radioTechnologyChanged
D/NotificationMgr( 964): hideDataDisconnectedRoaming()...
E/DataSettingButton( 940): onReceive()-S:
D/ConnectivityService( 834): getMobileDataEnabled returning true
D/DATA ( 964): [DC cid = -1]DcActivatingState msg.what=EVENT_SETUP_DATA_CONNECTION_DONE
D/DATA ( 964): [DC cid = -1]dataLinkInterfaceName=/dev/ttyCDMA0
E/pppd ( 964): Start PPPD Now
D/DATA ( 964): [DC cid = -1]DataConnection setup result='SUCCESS' on cid=-1
D/DATA ( 964): [DC cid = -1]DcActivatingPppState: setEnterNoticationParams cp,cause
D/DATA ( 964): [DC cid = -1]DcActivatingPppState: enter
D/pppd ( 1542): using channel 9
D/Tethering( 834): ppp0 is not a tetherable iface, ignoring
I/pppd ( 1542): Using interface ppp0
I/pppd ( 1542): Connect: ppp0 <--> /dev/ttyCDMA0
W/pppd ( 1542): Warning - secret file /etc/ppp/pap-secrets has world and/or group access
D/PowerManagerService( 834): acquireWakeLock flags=0xa tag=KEEP_SCREEN_ON_FLAG uid=1000 pid=834 myUID=1000 myPID=834 myTID=1100
V/DATA ( 964): [DCT] onDataCallListChanged:
V/DATA ( 964): [DCT] ---dc state list---
V/DATA ( 964): [DCT] ---dc list---
V/DATA ( 964): [DCT] cid = -1, state = DcActivatingPppState, ipv = IPV4, ipaddress = null, gw=null, dns=[null, null]
W/PowerManagerService( 834): Timer 0x3->0x3|0x3
D/PowerManagerService( 834): releaseWakeLockLocked flags=0x0 tag=KEEP_SCREEN_ON_FLAG myUID=1000 myPID=834 myTID=913
D/BatteryService( 834): updateBattery level:95 scale:100 status:2 health:2 present:true voltage: 4123 temperature: 256 technology: Li-ion AC powered:false USB powered:true icon:17302192
I/NotificationService( 834): New BatteryHealth : 2Old BatteryHealth : 2
D/StatusBarPolicy( 940): updateBattery level=95 plugged=true mBatteryPlugged=true mBatteryLevel=95 mBatteryFirst=false
I/StatusBarPolicy( 940): BAT. status:2 health:2
I/Launcher.BatteryInfoManager( 970): Battery time info is not available, retrieved from local.
W/pppd ( 1542): LCP: timeout sending Config-Requests
I/pppd ( 1542): Connection terminated.
W/pppd ( 1542): Receive serial link is not 8-bit clean:
W/pppd ( 1542): Problem: all had bit 7 set to 0
E/Tethering( 834): attempting to remove unknown iface (ppp0), ignoring
D/pppd ( 1542): using channel 10
W/pppd ( 1542): tcflush failed: Bad file number
W/PowerManagerService( 834): Timer 0x3->0x3|0x0
D/DATA ( 964): [DC cid = -1]DcActivatingPppState msg.what=EVENT_LINK_STATE_CHANGED
D/DATA ( 964): [DC cid = -1]LINK_EXITED
D/DATA ( 964): [DC cid = -1]CdmaDataConnection Disconnecting..., state = activing ppp
D/DATA ( 964): [DC cid = -1]DcInactiveState: setEnterNoticationParams cp,cause
D/DATA ( 964): [DC cid = -1]DcInactiveState: enter notifyConnectCompleted
D/DATA ( 964): [DC cid = -1]notifyConnection at 1339642762089 cause=UNKNOWN
I/DATA ( 964): [DCT] --------------------------
I/DATA ( 964): [DCT] Data call setup : FAILED
I/DATA ( 964): [DCT] service type : SERVICE_TYPE_DEFAULT
I/DATA ( 964): [DCT] data profile : CDMA NAI
I/DATA ( 964): [DCT] ip version : IPV4
I/DATA ( 964): [DCT] fail cause : UNKNOWN
V/DATA ( 964): [DCT] Data call setup failure cause unknown / temporary failure.
D/DATA ( 964): [DCT] Scheduling next attempt on SERVICE_TYPE_DEFAULT for 6s. Retry count = 1
V/DATA ( 964): [DCT] onUpdateDataConnections: reason=radioTechnologyChanged
V/DATA ( 964): [DCT] ---ds list---
V/DATA ( 964): [DCT] ds= SERVICE_TYPE_DEFAULT, enabled = true, active = v4:WAITING_ALARM v6:IDLE
V/DATA ( 964): [DCT] ds= SERVICE_TYPE_MMS, enabled = false, active = v4:IDLE v6:IDLE
V/DATA ( 964): [DCT] ds= SERVICE_TYPE_SUPL, enabled = false, active = v4:IDLE v6:IDLE
V/DATA ( 964): [DCT] ds= SERVICE_TYPE_DUN, enabled = false, active = v4:IDLE v6:IDLE
V/DATA ( 964): [DCT] ds= SERVICE_TYPE_HIPRI, enabled = false, active = v4:IDLE v6:IDLE
D/DATA ( 964): [MMDataConnectionTracker] getDataOnDunEnabled
I/DATA ( 964): [DCT] Ready for data :
I/DATA ( 964): [DCT] getDesiredPowerState() = true
I/DATA ( 964): [DCT] mCm.getRadioState() = RADIO_ON
I/DATA ( 964): [DCT] [DataRadioTech = RADIO_TECH_EVDO_A, data network state = 0, mMasterDataEnabled = true, is Roaming = false, dataOnRoamingEnable = true, isPsRestricted = false, desiredPowerState = true, mSIMRecords = , cdmaSubSource = 1/311870, mRuimRecords = ]
D/DATA ( 964): [DC cid = -1]notifyConnectCompleted() mWakeLock.release
Any ideas anyone?
Any ideas anyone?
wow!!! can't see or tell what that means!
I have roamed on prl 12121. The roaming triangle pops up then I get a warning notification in the top bar saying "you have lost data connectivity because you are roaming. I also get a roaming channel/SID.
I try to make a call and it puts me through to a different carrier telling me to call sprint. But I'm not trying to get kicked off boost so I don't.
That's the prl that IM using, maybe that's what the issue was. Not too sure.
Edit: Just figured out that my phone some how got stuck in uart mode. Switched it back and all is normal now. I'm not getting that logcat error anymore.
