I did the upgrade and there is still no data...
Can anyone explain it for me? Thanks.
Rogers is Scanning their network.. as soon as they can tell you have done the update your Data will come back on. try a power cycle as well.
for those of you who have rooted phones:
You can call normal wireless support (press 1 instead of going to pda/smartphone support) and request a "network refresh". Then you need to powercycle your phone and your should get data back!
I'm trying this right now. Just called rogers.
There's no queue on the normal wireless side, so if you want to speak to a rep this took me literally 1 minute to do.
Edit: Confirmed. It works. Just call rogers and ask for a "network refresh" and you have 2g/3g back on modded firmwares.
Tested on htc dream running cyanogenmod 4.2.13
by the way, those of you who have trouble upgrading should go to howard forums. There's a method to update the phone using a zip file. This one is for the htc dream. I don't know if there's one for magic as well. Good luck!
http://www.howardforums.com/showpost...&postcount=185
<snip>Granted emotions are running high right now but the contents of this thread have me annoyed and not with Rogers. I'm not being an apologist for their business practices and yes they've done some things to annoy us all but some of what's being said here is just childish whining.
<snip>
... If there's no OTA client with 1.5 then how do you suggest that Rogers preform the upgrade OTA?![]()
princess I am most certainly not a rogers spokesperson or work for them......they are very much my competition and the only reason I used them for personal services is because bell pissed me off to the point I looked elsewhere<snip>
Thank you for pretending not to be a spokesperson for Rogers.
Not buying it.
do you honestly think anyone affiliated with rogers would have posted about their rooted phone?
Hey guys, I just did the update on my magic, everything worked fine but there's something I can't figure out... I must be stupid or something.
Under "settings/Social networks" there is a place to login to facebook, and I have successfully logged in however... I don't see any built in app for facebook... has anybody else noticed this? you can login to it but there's nothing to use it with? :S
Hello Community: Here is one I would love to have your opinions on.
First issue: No 1.6 for Dream
Bought Dream outright locked Rogers phone paid full pop. Asked if I could participate in the swap for the Magic, simple answer no. More detailed answer yes if you sign up for a three year contract. (WTF?)
Rogers states that Dream is essentially a deprecated device. No updates past 1.6 (if that) Only choice according to Rogers themselves is to Root the phone.
Second issue: 911 update - Mandatory
Did not update (reason below) , lost data support at approximately 11:00 am PT Sunday Jan 24. Called Rogers tech support - min 30 min wait. Data outage creates mission critical loss for clients I support, which was the intended purpose for the device in the first place.
RogersMary - "For those who do not download the s/w fix, internet access will be disabled until it has been completed." (WTF?)
Third issue: (unsubstantiated)
As I understand updating the 911 patch includes a command that makes it impossible to root your phone with out bricking it. (see issue 1 above)
Summary: Rogers sold me a phone for $600, won't support it after six months, won't exchange it without me committing to a 3 year term, takes me offline for not updating the 911 patch, the 911 patch will not enable me to root the phone which is the only way I might be able to get any value out of the device.
Is it just me or is this unconscionable?
You may have to power cycle your phone to get data back. I just tried it now and it works.
2) I can
Same SIM being used on the magic and dream. Still have data on both devices this morning and according to my profile on the customer portal rogers still thinks I'm using the dream.Are you using the same SIM between the two???
From what I understand it is the account that is marked, so if you had your updated Magic up on the net long enough you have been baptized and your Dream will work.
Am I wrong here?
Oh, and happy that you've got your data back.
