chevy kernel fixed my cpu now i am good at 1000. will not fix the wireless tether. the icon says not installed
I backed up and reinstalled all apps with Astro.
That's supposed to happen. The only way to backup your apps and get the Market to recognize them again is if you download Titanium Backup and then donate $4
i did a wipe then installed BBv.8 and did a nandroid data restore and all my apps came back. market is fine and they update as well.
Hey guys,
So I installed this last night and I've noticed a couple of things and was wondering if anyone else has the same issues.
I'm running ChevyNo1's Kernal.
First, whenever charging my phone, it will only go up to 70% charged. No matter how long I charge it for, it does not go above that.
Secondly, I feel like the touch sensor is incredibly inaccurate after installing this ROM. I'll try to pull the notification bar down and it will press a button somewhere else on the screen. In Twidroid, I'll scross down and the result will be scrolling up. This doesn't happen all the time but when it does, it's incredibly annoying.
Should I try Adamz's kernal? Is his kernal a update.zip process or is it something different?
I'm not seeing those issue and I'm on AdamZ's kernel. It can't hurt to try a different kernel. AdamZ's kernels install as a ROM tgz file and it gives you a choice during install to which kernel to load, voltage and speed wise.
Alright thanks, I'll give that a try. Do I install the tgz file that same way I would an update.zip or is there a different method.
Also, my phone charged to 100% last night when plugged directly into the wall. I'm not sure if that 70% charge was because I was plugged into my laptop, I'll try again later tonight.
Oh and one last bug I noticed, my app icons disappear...a lot. I have to restart the phone to get them back, anyone else have this problem?
I finally got v0.8 up and running on my phone. I first tried to install Chevy's 10 slot 1.1Ghz kernel and it sent my phone into a boot loop, just like last time when I was installing v0.5. Retried with the 5 slot 1.1Ghz and everything worked perfectly. I've got 5 screens with lots of widgets, live wallpaper running and I'm at 1.1Ghz running smooth as ever. Definitely the best I've seen thus far. No problems whatsoever. Battery life seems to have improved as well. With my mild use yesterday and a few phone convos, I was at 70% from 8am to 10pm. Plus I was only losing 10% battery overnight without charging, as opposed to almost 40% before.
OMFG **** This, I should of never ******* rooted my ******* phone to begin with..I have absolutely NO clue what I'm doing!..And now my phone keeps force closing every 20 ******* seconds, And doing random reboots every time I unplug my phone from my computer..
Word to the wise future rooters, DO NOT ROOT YOUR PHONE AND USE ROMS UNLESS YOU KNOW EXACTLY WHAT YOU'RE DOING, OR HAVE A BASIC KNOWLEDGE OF WHAT TO DO, OR UNDERSTAND THE LINGO!.......
<----currently banging head on keyboard................
Need a little help...I downloaded BB .8 last night along with Chevy's 10-step 1.2, and everything is humming along beautifully....love this!
But....what happened to the Alarm Clock? It's not in this ROM, and I overslept this morning. Don't know if it was because the alarm clock didn't go off, or because the Allman Brothers were SO AWESOME last night!!
Just noticed the same thing (though I don't use the alarm clock). He doesn't list it in the "removed" section though. Suppose there's always a 3rd party app you can dl.
