AndroidHaCks
Thank you
i'll send a link.Sure kan I try I'm have SD external issue..
This is an alpha release of CM9 for the Optimus Elite so please don't expect this to be 100% stable
Those having SDcard issues, did you see my post earlier in the thread and try this?
I'm not running the CM9 yet but have the issue on Sleipnir after I would clear cache, dalvik, and fix permissions.
The phone shows the SDcard mounted, but can not access it. In settings; Unmount and remount. Everything works as it should after this.
Maybe it will work for those having the problem in CM9.
Someone that has a problem with the SD card mounting want to try a build to see if it's fixed?
So far the SD card is reading with the build u sent me. Will run it for a while to make sure all's good
2nd times the charm, No issues to report running nice & smooth, Thanks again to all involved!!!New build wont boot past the "LG Logo" for me
Did you try enabling the headset settings in the "DSP Manager" ??Just as a heads up, the volume control has no effect on the headset output volume. Regardless of what you do it, playing sound through the headset always outputs at 100%. 4/24 build, as far as I know, it worked in 4/16.
