AndroidHaCks
Alright, no problem. let me know if you need a tester
Anything not based off of a stock rom, isn't supposed to run gapps, but I guess you could until Google sends a cease & desist. So far only CM has received a C&D, but because of this, developers decided to respect Google and stick to the respective Google Apps rather than including them in their ROMs. I don't think I have ever seen a non-stock rom variant (PA, Hellybean, PACman, Rootbox, Aokp....) have gapps included.Custom ROMs can have gapps, cyanogen can not.
If you'd like to send them to me, I could see about updating my ROMs with them (since I'm getting the impression that stock doesn't have these updated ones by default).
I know I have libmmparser and libmmparser_lite( failed to open MM_PARSER_LIB, dlerror = Cannot load library: reloc_library[1314]: 18639 cannot locate
'_ZN7android11MediaSource13getBufferInfoERNS_2spINS_7IMemoryEEEPj'...)
Do you have the libmnparser.so and a few other libs that go along with that in system/lib? I can upload the 3 from stock that are missing if you'd like
Okay. Ima copy and paste this response. don't want to type it again.( failed to open MM_PARSER_LIB, dlerror = Cannot load library: reloc_library[1314]: 18639 cannot locate
Went back to the "4/13" build myself for the same reasonI just flashed back to the previous version without wiping data and it is way more smooth. I was having some bad lag with the 4/16 build. Anybody else? It might have been from Google Now because I didn't flash it this time.
How about the libmparser_divxblah? (it doesn't actually say blah) And libmposal?
Can someone please upload the 4 13 build for me? And preferably pm me the link
Has anybody done this yet? If not I'll do it now.
Like its been said before this is one hell of a good job, if it was my phone I would be ruining it, but alas I have a charge(loved the rom, to bad data didn't work.) Any who is my gfs phone, just wanted to ask how the camera is coming along?
I think slipnier overall had a better battery life..
