Root [ROM][4.0.4][BETA] CM9 for Virgin Mobile and Sprint 10/3/2013
okay but I can't get it out of the nandriod backup because.I cannot find it. I could get the kernel out of the old cm9 version I have saved on my laptop or I could just give you the old version of cm9. there seems to be some stuff built around that kernel so make a nandriod backup before trying it.
The kernel is the boot.img in the clockworkmod folder. But if you have cwm6 then it won't work. So if you installed with the apk method it won't work.
OK thanks
Been trying to upload but i get the following error:
Your submission could not be processed because a security token was missing.
If this occurred unexpectedly, please inform the administrator and describe the action you performed before you received this error.
Anyone know how to fix this?
Anyone having any ringtone issues? I've been working on this ringtone issue of mine for most of the day. When a contact calls I get nothing no matter what tone I choose. When a non contact calls the ringtone I have as default plays without any problem.
I think I've experienced the same thing.
This happened to me too. I thought I just had the volume too low.
Don't know if this is particularly bug related, but it seems that RAM is handled less optimally than stock in current build. Also experiencing more laginess during downloads than usual.
Sorry about the current bugs you guys are having. Ill try to fix them but I don't have any of the bugs are guys are having. I nearly close for the camera fix only 5 errors is preventing the camera from starting but even if I fixed the errors im not sure it will even work. I fixed mass usb storage so it works on both sd cards. Wifi tethering appears in tethering settings but when enabled it breaks wifi and you need to restart the phone to get it to get wifi to work again. nfc is a mystery to me I don't know what to do on this one. Then I still need to work on the kernel to make it more stable. alot more things to do.
Hey no prob man, I know there will be issues, that's a given. I'm just stating things to try and be of potential help (probably not though)
Isn't there like a log or something that we can show you as far as bug reporting goes? I'm not sure how to get you one of those, as I've never done it.
Yeah I added a link for an app called "Getlogs" in the OP. It uploads the logs to pastebin.com for you in a push (tap) of a button. just give me the link it provides for you.
Take your time brother, your doing an awesome job so far
Hmmm, well the app just gives me this error....
Edit: old version of the app, my bad, the new one says it places the log into emmc/android/data/blablablah but it isn't there.
Thanks phenomx glad to see your updates and your working on that new kernel to get it more stable. Do you think in the next update you could put Google now and gapps all in the Rom? I know it will make the zip bigger but it would make the update process a lot faster and easier. I wish I could help you and do more other than cheer from the sidelines, oh well. I might try to look into some programming to try to help out.
Google doesn't want people to put gapps in their custom roms.
I have an adreno 205 libs update Phenom if you want them. It has a few errors in logcat, so I guess they need a few small tweaks, but I can definitely tell a performance increase. It has a pretty big gpu increase and total score increase in antutu
Thanks but I'm already using updated libs in my test builds.
