totalrecarl
Try my inverted apk.
Link? My Gmail app also does this.
Look here..Link? My Gmail app also does this.
Does anyone else have a white gmail problem [...]
This rom is getting better and better. Once the EVDO "switch" (contacted playfulgod and he believes its an issue in the CMSRC.) andcamera are sorted its a RC with minor bug fixes. Good work Phenom! I have my machine set up to do actual ports of xxhdpi, xhdpi and hdpi theme engine themes for mdpi. Legitimate ports not doing dpi hacks.![]()
So you mean to say that the 3g EVDO signal dropping issues is more likely software then hardware? A new kernel might fix it?
I'm no code expert but similar issues in other CM9 builds point to the RIL (Radio Interface Layer) of their respective devices for this issue.
Here's another set of logs. seems like the audioflinger issue is gone but mediaserver still crashes when I open the camera.
logcat:
new camera oe cm9 - Pastebin.com
dmesg:
Nice rom! But can you give an Estimated Time Amount when the camera will be fixed? Thank you.
The camera will be fixed on September 28th 2013, 11:32 GMT.
It's hard to say but I'd rather get rid of the performance issues first. Im trying to get the camera to work but it's VERY difficult. At least for me.
My only real concerns (performance wise.)
Not having EVDO (reporting anyway)
ICS creates a wicked amount of cache which makes the stock browser laggy.
Trebuchet is laggy and seems to redraw a lot (sorted that with apex)
Will post DDMS log cats when I get home.
I agree with the stock internet browser but trebuchet is pretty good I would say but if you would change it to another 3rd part launcher choose Apex launcher or the mainstream one Nova launcher
