Quentin638
Member
How long should the first boot take mine seems frozen but you said it should work, what is the approx. waiting time for the 1st boot?![]()
I think it freezes I had to reset everything on my phone
Did it work after you reset your phone?I think it freezes I had to reset everything on my phone
Is this a deodexed rom?
Code:#include <std_disclaimer.h> /* * Your warranty is now void. * * I am not responsible for bricked devices, dead SD cards, * thermonuclear war, or you getting fired because the alarm app failed. Please * do some research if you have any concerns about features included in this ROM * before flashing it! YOU are choosing to make these modifications, and if * you point the finger at me for messing up your device, I will laugh at you. */
Hello peoples! I present you with Super Helado. Just what is Super Helado?
Also known as Super Stock ICS, Super Helado is a ROM based on Complete Stock.
It features things from Android 4.0, 4.1, & 4.2. I hope y'all like this ROM.
Changelog:
v1.0
- Removed ALL Samung / VM Bloat
- Removed Google Apps
- Replaced Most TW Apps With Stock Apps
- Added Apps2Ext Support
- Added Beats Audio Mod
- Added Custom Bootanimation Mod
- Added JB Boot Animation
- Added Face Unlock
- Added JB 4.1 Fonts
- Theming Progress Is ~70%
v1.1a
- Fixed Wi-Fi Direct In Settings App
- Fixed Mobile Networks In Settings App
- Theming Progress Is ~80%
- Switched To TW SMS App
- Switched From JB 4.1 To JB 4.2 Fonts
- Added JB 4.2 System Sounds
- Added JB Transitions
- Added animania260's OC Kernel
Future Updates Include:
- Suggestions?
Bugs:
- You Can't View Gallery From Camera App
- You Tell Me
Screenshots: (v1.0)
Installation Instructions:
1.) Download The File
2.) Put File In Your SD Card
3.) Boot To CWM Recovery
4.) Make A Backup (Optional But Recommended)
5.) Format Data / Factory Reset (Optional But Recommended)
6.) Flash The File
7.) Reboot
8.) Success!
NOTE: On first boot, the boot animation may seem frozen after a couple of seconds but that's because the loop counter ended. Just let it boot. Also, be activated before you switch to this ROM because it doesn't come with the activation app.
Super Helado v1.0: Here
Super Helado v1.1a: Here
Extra Google Apps: Here
TouchWiz Apps: Here
Big Thanks Goes To:
Dsixda - For His Android Kitchen
Croniccorey - For His A2SD++ Mod
...Awesome... - For His Beats Audio Mod
Anbech - For His Custom Bootanimation Mod
Tommert38 - For The JB Bootanimation
Yash98 - For The JB Transitions
animania260 - For The OC Kernel
The CM Team - For Making CyanogenMod
Google - For Making Android
Samsung - For Making The Samsung Galaxy Reverb
Virgin Mobile USA - For Releasing The Samsung Galaxy Reverb
Hit "Thanks" or "Like" if you like this ROM.
Changelog:
v1.0
- Added Face Unlock
v1.1a
- Suggestions?
Bugs:
- You Tell Me
Screenshots: (v1.0)
6.) Flash The File
7.) Reboot
8.) Success!
TouchWiz Apps: Here
Big Thanks Goes To:
Do you recommned v1 or v1.1a?? Can i have both at once??
I just flashed this rom to my Reverb and I turned on the phone and the boot animation didn't play and the screen didn't turn on. I would press the lock button and the backlight would come on and all the haptic feedback works and the charging led is on but the screen won't show.
Do I need clockwork or can i just slap the ZIP file on an SD card and boot into recovery and navigate to it there?
thanks
I see a ton of people using CWM, but you have to have a rooted phone PRIOR. I do not have a rooted phone nor care to. Plus all of the techniques used to root the Reverb do not work after the JB update. Just want the new stock POS 4.1.2 to go the hell away and never come back. Flipping back to 4.0.4 will be great.
thanks again.
Have you used this app on the reverb because i want to try it, but i don't want to brick my phone.
Thanks
i get boot loop with this man and when i hit power button the screens goes off and on as if its on and just replaying a video over and over again i did not reset everything
