electro00nerd
Member
What about having an ad away built into the rom or something like that
I think it's because he removed connections optimizer
Downloaded Gravitybox has some useful tools .but that's good for older model phones for gb ...I'm not knocking on no one but this rom is a remake of drangongart6505 yeah there's slight differences anyways I still like what you guys done for sure its still better than stock also can't wait to see this rom prevail
Its not a "remake", its my rom as the base. Yes some things are different. But I did approve the use of my deodexed files so...
Id like to see this rom go far as well. However I will from here out not approve the use of my files. I am actually going to make sure that I alone can identify my modified files. I'm not knocking brittnearl at all, like I said I approved the use and also requested that I was credited for the files. But it is at its core my hard work. I would like to see you attempt further developments on your own. Its too easy to take something, rearrange its contents and claim it your own.
Good job on this, it does look great!
Even if i deodexed myself it would still look the same as dragonart6505 as they are based off stock rom, i did ask permission before even posting my rom. Thanks for all your hard work again![]()
I'm not downing your rom brittnearl there is a slight difference I like about your rom as of dragongart6505. When you have two roms so close to same it basic comes down to a popularity contest ...I like what both you guys done thanks for the hard work and choosen the awe to customized I'm really please to see both of you to prevail and maybe come out with a super hybrid rom together
I would love to come together, instead of making 2 different roms take all the feedback and make one great rom:-D
Theres some things I'm working on and the rest of the crew too. Were slowly trying to generate an entire team (I think we were discussing "Zurg" or something) so long as theres is actually a skill set that can be brought to the table. Even if there isnt, ideas and collaboration are a great way to get things moving.
Maybe sometime we will...
I'm just not a huge fan of the CM stuff. I love the roms, dont get me wrong, but I'm not a "brand" kind of guy
Ok now well brittnearl your stock alarm clock doesn't work ..so ill have to download one from the market..
Well u can listen to my voice mail bye opening the dailer and pressing the one key
Yes I can listed to the voicemails fine, but I don't get an indicator in the status bar anymore telling me a voicemail is waiting
and you wont unless the VVM app is installed
Do you have the VVM app? Is it an installable APK or do you have to flash in recovery since I assume it was originally a system app?
