thegoogleman
You could back up your data and then put it all back on I think.
All u have to do is follow my other guide here it will put u stock unrooted
Sweet, and will this wipe my whole SD card? Or just the phone?
So is this going to just be an update from the previous build, or another update to wipe my phone completely? Just wondering before I download.
That's what I was afraid of. I'll stick to my current build then cuz I have no WiFi and it eats my data to reinstall everything.
Or backup your current ROM and do an advance restore of data.
Could you give me a quick tutorial on how to do so?
im using 2.6 as is with srs off and no other audio mods and i still got probs, but it just happens rarely during normal use that im not even bothered anymore. quick test i do is just running my finger across the capacitive buttons back and forth real fast and i get that dreaded bzzzt sound within the first 5-15 seconds.Hey devs, I just thought it to be note worthy that the latest update of the White moonshine version has seemed to fix my audio. I haven't noticed any pops or cracks, or skips. I can use Viper4Android just fine and the music sounds good. It seems weird to me that something simply based off the same stock stuff we've been working with would fix the audio problem, but maybe there was some conflicting things in the system.
The audio issue is not a rom issue as my device has done it since new, im guessing a driver issue as if u run a log cat there are audio device strategy errors
Which app do u use to get log cats?
If u know how to read logs catlog is pretty nice for self development
Found the problem with the audio, but fixing it will take some time
Y dont u enlighten us then??
E/AudioPolicyManagerALSA(267): getDeviceForStrategy() strategy 5, device 80 found a bunch of errors like this. I haven't been able to find anything for this yet
The (267) is what they all have in common so I'm searching for an answer and hopefully I can help somehow
After some quick research it appears to be deprecated audio drivers at the kernel level. Thanks ZTE...you never fail to be the source of the problem.
Arrrgg, so our kernel is all kinds of screwy.
It's not just the kernel lol, they added there code through everything
Sounds like our sound is gonna b screwy for a while
I haven't had any problems with sound. What problems are you having with sound.
