Root [ROM][ACS][aosp] Kings UNleashed GB-R3 NEON [GBR3-4/17/11] " KING STYLE "
MizzouBrent
Android Expert
Obviously I take no credit for this.
http://forum.xda-developers.com/showthread.php?t=887882
King and the Android Creative Syndicate bring to you once again ....
Kings UNleashed GB R3 NEON
Well our last release was a DC13/CM7 build!
This time around we have decided to work with a salvage MOD build! Everything should be working just like before!
Custom NEON green theme I ported from another device!
Custom default wallpaper
Custom evokings Boot animation from wrx4me
Themed NEON Launcher Pro
Titanium backup
WiMAX Key check
Voicemail
HDMwIn for hdmi connection
Spare parts
Superuser
Custom transitions
And all the fixins!
Working:
Gps
4G
Nav
Hdmi
Downloads:
KingsMOD Format all zip
R3 Kings gapps
Kings GB NEON R3
Nah....been taking my time looking for deductions .....its a great thing not having state taxes.....claiming sales tax and having expensive hobbies ;)
Took it from owing 800 to getting back 800. Go me
Good you can do mine next year. Jk I always just take the standard. Snagged 2 g's this year for 15 minutes of filling out on turbo tax, holla
I got a 6500 homebuyer credit plus two mouths to feed so it was a good year.
I'm running cm base of this rom and its great. I would really like a themed task bar. My GPS locks same as it does with CM7 and my video playback is actually better. I was having video stuttering issues with CM7 final but everything on this rom is rock solid.
I have tried both versions briefly, at first I tried out the SM version and then some of the settings FCed so I flashed the CM version. I went to set it up how I liked and couldn't find the Microbes wallpaper or the Red Theme so I went back to R2 lol.
any way to fix the signal bars on this rom or any gb rom for that matter cause on my stock rom i have 4-5 signal bars that shows but on this one and any custom roms thats not sense i only get 1-2 bars, now when i had my hero and i flashed any aosp rom i had that problem but then i found darchs visual fix and used that to fix the signal bars but when i tried to do the same method on my evo it just freezes my phone any help would be great.
This rom is really nice and really fast but I always get 1x one speeds as opposed to 3G signal speeds so I always go back to Sense roms. If I know how to fix that, I'd use ASOPs all the time.
Most Sense roms show 3g even though you might be getting a 1x signal. AOSP shows the correct one that you are receiving. Do a speed test on Sense and AOSP and see if they are comparable.
AOSP ROMs have a different way of calculating signal strength, instead of 6 total bars it uses four. So you are actually getting the same signal strength it just looks different.
