Root rom acting insanely weird
cammykool
Android Expert
okaty my copy of backsoide is being weird like its not unlocking at times as in il push the power buttion the 4 lights at the bottom will light up but the screen goes dark and eventilly goes like staticy so i have had to pull the battery 4+ times today did i get a bad flash?
and out of curiosity how is harmonia 2 i want to try i simply because its about as bare as bare can get
I don't know the specific builds, as I don't have your device, but it sounds pretty classically like a corrupted file. If you made a backup, flash back to that, re-download your ROM, wipe data/cache and flash the new file.
Unless...the one other thing that can cause it is if you use Titanium Backup and restore system data. You only ever want to use TB to restore apps, never anything system because it can seriously mess with your ROM.
