roadkill42
Android Expert
Something not right what dirty unicorn u on I do not get any reboots when phone sitting charging strange
Don't really know something with the government if u ask me security crapSo what's the difference with enforcing versus permisv?
Thanks for looking into these kinda things u can easily say the hell with awe this may be the braking point to successYeah there's several of those looking for peripheral-loader.c its something PhenomX4 will have to answer I'm not sure what his kernel is based on these days ... Looks like there may be a conflict with SELinux... You guys say its saying permissive but in the log it says enforcing... So that too is above my pay grade. See the attached another potential SELinux issue.
Yeah there's several of those invalid firmware metadatalooking for peripheral-loader.c(pil get errors) its something PhenomX4 will have to answer I'm not sure what his kernel is based on these days ... Looks like there may be a conflict with SELinux... You guys say its saying permissive but in the log it says enforcing... So that too is above my pay grade. See the attached another potential SELinux issue.
No problem man, sorry I wasn't much help...seems like we came up with more questions than answers lol.Sweet bro, definitely thanks for all the effort and insight. You're a solid ass dude in my book
... I'll try and restore my B05 tomorrow and then flash 5.1.1 again to see what happens.
I think step in right directionNo problem man, sorry I wasn't much help...seems like we came up with more questions than answers lol.
Here's the project homepage, good info.So what's the difference with enforcing versus permisv?
Unfortunately I'm running KitKat nameless simply my favorite ROMEdit*
Actually, what is the build date on the 4/29 build for those of you running it? Or the original 4/28 CM 12.1?
@phenomx4 I'm not sure when you synced your sources lasts but there's been a ton of commits for memory leaks, permissions and CMSDK...also a lot of MVNO support added in the vendor blobs. (Falcon change log for example)
http://www.cmxlog.com/12.1/falcon/
:good: good looking out
Step 1. Root (which you have)Hey guys I'm a newb with this stuff installing custom roms and whatnot. I have a rooted 4.1.2 B01. Will this rom work easily for my phone? I'm downloading it right now. Once it is downloaded, do I just move it to the root folder and then on the reboot window, choose the "apply update from external storage" option? How does this custom rom installation work? I didn't see any instructions on here... sorry for my ignorance, newb..
Step 2. Custom recovery which can be found in this forum. This can be easily done by flashify or other similar market tool. (Or fastboot)
Step 3. Create a nandroid backup of your current ROM. (In case something goes wrong)
Step 4. Download ROM and GApps package and place on the root of your SD card.
Step 5. Wipe data/cache/dalvik cache
Step 6. Select to install from SD card first the ROM then GApps.
Step 7. Reboot and profit. [emoji106] [emoji16]
Did I miss anything folks?
Doesn't phenoms updater script format system on install?*Yes*
@KellyDraves
In Starkravings number 5
You need to wipe system as well whenever upgrading OSs.
... So
In custom recovery
*mounts and storage
/format system
/format data
/format cache
*advanced
/wipe dalvik
Also I always do:
*Wipe data/factory reset
*Wipe cache partition
^^all in recovery
-follow the rest of what Starkraving has posted-
*Yes*
@KellyDraves
... So
In custom recovery
*mounts and storage
/format system
/format data
/format cache
*advanced
/wipe dalvik
Also I always do:
^^all in recovery
PS: all (*) are indicative of options found on the first screen of your custom recovery.
Are you on a stock recovery?I do not have any of those as an option on the first screen in recovery mode xD only options include
-reboot system now
-apply update from ADB
-wipe data/factory reset
-wipe cache partition
-apply update from external
storage
-apply update from cache
-md5 check
-reboot system now
storage
-md5 check
Also I would format internal SD it will elimate a lot of problems what I was told and it worked great thanks starkAre you on a stock recovery?
I would flash twrp. to me I have less problems that's just my opionI do not have any of those as an option on the first screen in recovery mode xD only options include
-reboot system now
storage
-md5 check
