Root [ROM][ALPHA][5.1.1] Dirty Unicorns 4/29/2015
I haven't tried it out yet any good features
Nothing that DU doesn't have, really it has less features. I just happy that everything works (beside flashlight in settings crashing, will have to pull a log). I like the simplicity of the rom. Now to figure out how to fix my wifi reseting my phone.
Does ur stock browser crash
so been running this rom for 2 days and it's amazing a little laggy and buggy but amazing. is cm 12.1 better or the same? jw
If you visit the parent link to the ROM for the development team, your device developer's gerrit or for a supported device you'll be able to answer your own questions. Firstly the same bugs that are found in CM are found in ROMs that use CM as a base(Unless the team/developer of the build fixes it him/herself.) There's basically three primary bases CM(which uses both AOSP and CAF), CAF(Qualcomm devices) and AOSP(Vanilla Android) most custom ROMs are built on these bases.
So if you know what bugs effect the base ROM you'll know what bugs are likely present in various team build spinoffs.(again unless those developers fixed it themselves) you can always view developers change logs and their gerrit and see what's going on and changing from build to build.(by viewing commits/merges)
