PlayfulGod
Extreme Android User
DISCLAIMER: This is a CUSTOM' ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Here ya go folks, CyanogenMod 10 for the LG Connect!!! Well, let's be honest, unless you're living under a rock, you probably know what Android 4.1 (Jellybean) is. Furthermore, you should know what the CyanogenMod project is. However, if a rock is really your home and you'd like to learn more, please visit their site: CyanogenMod | Android Community Rom based on Jelly Bean
Version: 20130312
Developer(s): PlayfulGod
Description: CyanogenMod 10 for the LG Connect
Source: github
Forum: Unleashed Prepaids
Wiki: Wiki - Will be updated first!!!
Status: ALPHA
Note:
These builds are not intended for daily use yet!! Use at your own RISK!!!
CyanogenMod 10
What is this?
This is a build of the popular CyanogenMod 10 for the LG Connect 4G. This is built from source.
People to Thank
Whats Working?
Whats Not Working?
Changelog
Kernel
Screenshots
How do I install this?
Downloads
Version: 20130312
Source: github
Status: ALPHA
Note:
CyanogenMod 10
What is this?
People to Thank
- koush - for his kickass recovery.
- CyanogenMod - for the best ROM out.
- tdm - for his kernel guru-ness.
- stcarlso - for his mods to the lge-kernel-iproj src for the LGxx840.
- adknight87 - for his dedication to trying to learning and work on this project and inspiring me to work on it.
- jlede - for posting he boot.img he repacked.
- To anyone not mentioned!!
- numerous testers - thanks for testing & keeping the faith.
- The Community in general, after all you all are why I do what I do.
- IRC - for the ongoing help and shared knowledge.
- #oudhitsquad (Freenode)
- #cyanogenmod-dev (Freenode)
- #koush (Freenode)
Whats Working?
- Audio
- Bluetooth
- Wifi
- Voice and text
- Front & Rear camera
- Data - for some, but not all... yet
Whats Not Working?
- Data
- MMS
- Video from Front camera
Changelog
- 03-07-2013
- Initial Release
Kernel
- Source - [github]
- Overclocked to 1.5Ghz
Screenshots
- N/A
- Download the .zip & copy to phone or sdcard (make sure 4g or wifi is enabled if dl'd from phone).
- Zip can be installed from either internal or external sd in CWM (Which ever you copied it too!)
- MAKE A BACKUP!!!
- DO A FACTORY RESET!!! - this will wipe data & cache!
- Go to install zip from sdcard
- Choose zip from sdcard
- Select cm-10-xxxxxxxxxx-UNOFFICIAL-cayman.zip
- Confirm
- Repeat Steps 5 -8 for gapps
- Reboot
Downloads
- Build 0317
cm-10-20130317-UNOFFICIAL-ms840.zip
Code:md5sum: 722960bda808318715323ef5254afc1b - Gapps
gapps-jb-20121011-signed.zip
Code:md5sum: 4e9e7ec3c22b0b3471bd05d62b8a659d
Anybody try this out yet?
Well.. Kubuntu. Ubuntu is just.. too simple for me. Kubuntu is amazing though. I want to get used to it more since the few hours I spent with it, I simply loved it. I will, however, one day buy WIndows 8 (since the pre-installed version was from the OEM, and so.. yeah. e.e) I am short of money as of late. .-. So don't really have a choice, lol.
