Root [ROM][ALPHA] Quattrimus ICS (CM9, AOKP40)
tdm
Android Expert
Announcing Quattrimus: ICS for the LG Spectrum
What works?
Phone, SMS, Sound, WiFi, Bluetooth (sort of).
Cameras.
What does not work?
GPS.
Bluetooth for audio calls.
Mobile data can be finicky.
Credits
death2all110 and PlayfulGod for providing vendor binaries and a bit of help here and there.
Neph81 and death2all110 for finding the patches to fix mobile data.
Code Aurora Forum
The CyanogenMod team
The AOKP team
Many, many others
Download for CM9
getquattrimus.com [Hosting by Chris Talkington, TalkingtonTech]
androidrepo.net [Hosting by Jeremy Countryman, HardCore FX Web Design]
vmroms.com [Hosting by LeslieAnn]
Current Version: beta1
md5=98f02cfbf16c8ea7a3de1ad81d6aadee
Download for AOKP40
md5=6672a692ef738a07825f12e8a52a1641
Install instructions
* Install the latest recovery. As of this writing, it is CWMT 6.0.1.1. See other threads in this section for how to obtain and install it.
* Download the ROM, verify the md5sum, and put it on the root of your sdcard.
* Download ICS gapps from goo.im, verify the md5sum, and put it on the root of your sdcard.
* Power off your phone.
* Hold volume-down and power until you see the scary warning screen.
* Confirm by tapping the power button twice.
* Make a backup of your current system (use the tar method!)
* Do a full wipe / factory reset.
* Install the ROM.
* Install gapps.
* Reboot.
Donations
I don't accept donations. Please donate to the EFF or one of the hosting providers.
Nice one. I'm amped to try the AOKP. So does it look like the stock Spec rom? I ask, because the AOKP for the Transformer had all the transformer stock apps and essentially looked stock. It was confusing, since I thought AOKP was based of AOSP.
BTW, is this the ICS or JB build of AOKP? I ask because both are available and it will determine which gapps we dl.
AOKP looks like ... AOKP. :) Its main claim to fame is being very customizable.
I haven't added any stock apps yet, but I might in the future.
This is AOKP milestone 6. It's pretty much the last ICS code before the developers switched to JB. I will be working on CM10 and AOKP41 soon.
Where does the name "Quattrimus" come from?
It's from when I started doing ICS ROMs for the VM670 (Optimus V). The developer "lupohirp" on xda was the first to successfully get ICS going on that phone, which was quite an accomplishment as support for the old ARMv6 CPU was officially dropped by Google in ICS. He is from Italy and quattro is Italian for 4, which is the version number for ICS. So I mashed up quattro and Optimus to make Quattrimus to pay homage to his great work. :)
Nice. So did you keep the aosp look or did you customize it at all? I don't care either way, I rather like aosp for ICS... The aokp for the Transformer threw me for a loop, though. I did expect a stock looking rom.
I'm loving this so far. I'm using my fascinate as my DD so I can't test SMS and calls.
MrB. The only difference between cm and aokp are basically just customization.
Does anyone know why none of my music players will see my music?
I'm attempting to start on the ROM I'm building. But I want a working music player in it before I get too far into it
I've used multiple file explorers with no problems. They all see all my files. Plus call of duty black ops can see the SD files. But I can't get music to work. I've never seen anything like this
yea I can adb shell > cd sdcard just fine, get to it with install rom in ROM Manager, and see it in settings > storage. Not tried any other apps as I havent installed gapps yet. ;)
Its probably a simple fix. I blame LG. And you should try the blacked out gapps. They look amazing on the spec
try darkjelly by djdarkknight ;)
And the sdcard is mounting fine, the Gallery even sees my pix on my sdcard & even saved the screenshots I posted on my to it. ;)
It mounts, but I find I can't restore apps with rtb. I don't know if that's an issue with the backups (though I was restoring the app only, no data) or with the rom, but I can access other stuff on the sd card.
Sorry, i thought i read somewhere that the SD cards didnt mount.
I'm wanting to say that was the before the first build was released. Because I remember reading that somewhere too
So far battery life on aokp is holding up nicely. Its not activated. But airplane mode is off and its just using WiFi and screen at full brightness. Only dropped 20% in 2 hours. Better than what I get on stock
I tested out AOKP and dammit all if I don't love that boot animation to death.
I noticed it, like CM9, set the network to nv, instead of sim, so I had to manually change it before it would recognize the sim card. The phone actually tried to call *228 to activate, which was hilarious because the keyboard doesn't pop up.
It seems like aokp is a bit slower than cm9. Am I correct or is that just my experience?
It seems like aokp is a bit slower than cm9. Am I correct or is that just my experience?[/QUOTE said:
i haven't flashed aokp yet on my spec. but when i had the fascinate and i flashed aokp that shit was hella slow compared to cm9.
I just setup face unlock for the first time ever. Yeah I'm slow lol. Seems to work fine on this ROM. :thumbup:
