Root Rom and Recovery
benwalburn
I recently rooted my transform by flashing cwm using a script I found on the forum, then rooted by flashing a zip I found a while back.
Anyways I have root access, but the phone doesn't work right with adb. I can't remount the system using any method.
I am hoping that a rom will fix this, but I don't know which work on the boost version, if it makes a difference. Also, did I flash the incorrect recovery? I do get a couple errors when it starts, but it seems to work fine.
Sent from my DROIDX using Tapatalk 2 Beta-5
You probably want Shevron ROM: http://androidforums.com/transform-...on-rom-version-5-3-1-updated-5-19-2012-a.html
As for the CWM errors, do they say "E: Can't mount /cache/recovery..."? If so, that's fine.
I flashed shevron but I'm still getting "operation not permitted" in adb when I try to remount.
adb shell
su
remount rw
I'll try that as soon as I can get my hands on it.
But does anyone know if Heimdall works on this phone? I use ubuntu normally, and finding windows is a bit of a pain
Ok, remount rw works. Shame ADB remount doesn't lol
