G
g60madman
Guest
It's the nice thing about 4ext recovery is you can just format all partitions (except SDCARD).
Sure thing. Could you clarify, in case anyone else runs into this: did you in re-install joe_bloe hacks or remanifest's "fix everything" zip, or did you just do a more thorough wipe?Ok, so tried this. Cleared cache and devl or whatever its called. Then cleared all partitions except SD Card. Then noticed the first thread was updated earlier today. So followed that, did the ROM first, then VM, then GAPPS, rebooted and now its working like a champ.
Thanks for the assistance.
They're both made for CM10. They work. I'm using ButteredToast right now on this rom with S2W with backlight.
That's a feature, showing that there are other available lockscreen "panes." Hold your finger on the extreme left edge of the lockscreen, then swipe right... you'll see a plus in the center of the screen. That's where you can add a lock screen widget, say a list of your appointments for the day or a Beautiful Widgets weather screen... in my case I use SeriesGuide to display which of my favorite TV shows are coming up.I really enjoy the rom, you did a fantastic job with it and it has brought new life to my phone. I have one thing that is bugging me though, on the lock screen, is there any way to remove the two lines that appear on the left and right side when pressing the power button to bring up the lock screen? It just really looks out of place.
Not sure if anyone else has had this issue after Installing this ROM, but now my phone does an endless loop. I starts up and shows white screen with HTC logo, then goes to CyanogenMod circling blue logo and then reboots back to HTC logo and then over and over
I tried wiping all and install ROM again, but no dice
Maybe a stupid question or already answered. For whatever reason, my lock screen weather widget is showing in Celsius. Once I unlock the phone, the other weather app shows in Fahrenheit. How can I change this so the lock screen shows Fahrenheit as well?
neither work, they dont boot.
I don't know about Anthrax because I, like many, have been locked out of dev threads. My understanding was that his most recent build had 4.2 support.
But ButteredToast... there's a test build on something like page 15 of the thread for 4.2. The main builds (like 17.3) don't boot on 4.2. I imagine his next update will add full support for 4.2 in main builds.
I'm on a quest to wring more battery life out of my phone... at the moment I'm swapping my battery out twice a day if I'm not actively charging.
I'd love to hear suggestions from my fellow Angry Bean users. If you've been able to substantially improve your battery life can you please share what you did... kernel switch, governor or cpu min/max adjustment, 3rd party app, etc? There seem to be wildly different opinions out there (underclock! overclock!), so I'm sure we'd all love to hear actual results from others on our device/ROM.
FWIW, I noticed yesterday while at home that my #1 battery hog was WiMax settings... as I've mentioned before, when I'm on WiFi my phone endlessly cycles WiMax on and off. The WiMax log fix has at least kept that process from eating up my available memory, but it would seem I'm still paying a price for that constant cycling. I'm going to have to be more proactive about disabling WiMax when I'm home... actually not very easy to do, as there's only one slim window in each on/off cycle when the main WiMax checkbox can actually be unchecked.
mastersoup, here's the one I found and successfully installed: http://download.negalite.com/bigwillyg/ButteredToast-NoAroma-04022013-CDMA.zip -- if that's the same one, can you summarize the reported issues so I can verify whether I have them?
I only just installed it... I've read reports of increased responsiveness, and better battery life. It also enables you (with help from this app and this app) to enable "fast charge" (removes forced trickle charging when not on a standard charger) and "sweep2wake," which lets you wake or sleep the phone by sweeping across the hardware buttons.What advantages do I gain by flashing this kernel? Just curious...
So... how do I access the Beats Audio settings?Beats Audioand some unimportant things about performance...
No settings. Built into the sound drivers. No notification like on Sense either. It's just there. If you have some high quality 'phones and songs you'll notice it.
I used Titanium Backup to restore my apps. For some reason they are taking forever to update, if at all, still waiting.
