Gotta say except for the amount of battery the Rom is eating i'm enjoying it. Ofcourse you know i had to modify it for my personal use before flashing it. My Tweaks and Acid Audio definitely makes this a class S Rom :thumbup:
Screenies:
TWIMC, this version appears to still be incompatible with the most popular 3rd party kernels.NEW FEATURES
5/2/2103
∙ Battery is lasting longer
∙ Phone is not getting hot anymore
ohh yes flashing it right nowNEW FEATURES
5/2/2103
∙ Bluetooth is pairing perfect
∙ Video playback is stellar
This ROM is totally Chairshot's work. He fixed the kernel and a lot of issues related to the kernel. I have been running this since the 3rd and it's been flawless. Also making it through the night with out a charge!!
NOTE: Also with future releases we will be running the ROM's a few days before releasing it due to the overheating issues and other bugs the last ROM had.
The 0403 release was the last one I was able to install the MiRaGe kernel on without having it hang at the white HTC screen... this also happened to others on 0501 with MAC and Anthrax, and to me and others with Buttered Toast. I reverted to 0403+MiRaGe after the battery/overheating issues of 0501... I'm now trying out 0502 with the included kernel, in the hopes I'll get similar performance & battery life to 0403+MiRaGe.
Thanks again to all the contributors for their work on this ROM!
I am noticing crashes when I am recovering apps with titanium backup.
Same here
Anyone know how to disable the quick settings menu popping up when I I pull down from the right side of the screen? I mean, I still want it, just not to be brought down when I pull from the right side.
System Settings>System>Quick Settings Panel>Quick Pulldown>(choose here)![]()
Can I update without flashing? I am on the 5/1 release.
I have been testing for 2 days now and everything is running great and smooth !. however, im getting weird forecloses on the msg app every time i get an mms.
I have this problem, how I got around it was wait 30 minutes and then try again. If it still fails try a hard boot.
mrbenji,
The MiRaGed kerenel is designed for ICS/Sense this may be the reason for some issues with it not working properly with the CM10.1 branch as CyanogenMod is updating that branch every hour on the hour.
https://github.com/cyanogenmod/
This is what also makes the 10.1 not as stable as say the Jelly Bean Branch as this branch is being updated so often.
Did reboot and still no luck. downloaded go sms pro and thats how i was able to get the mms. but i dont like that app at all, prefer the stock one :/
Anyone else having a MMS issue where whenever you attach a file and sent it messenger force closes?
