Root [ROM][AOSP]dGB v01_28_2012| 2.3.5| 375MB /data| 60MB /system |Mult-lang |Unlock |Reboot[28 Jan]
Change log
v 01_28_2012
  • English only and Multi_language Version
  • Custom tweaked dGB ManU 2.1 HAVS AXI CFS Kernel (Optimised by Eviollet for dGB specifically)
  • Lockscreen Unlock Options Returned
  • 3-in-1 reboot menu
  • Returned to 15 step Volume due to PowerAmp issues
  • Memory Tweaks less aggressive
http://www.mattman.org/rootsu/rootSU/dGB_01_28_2012_eng.zip
http://www.mattman.org/rootsu/rootSU/dGB_01_28_2012_Multi-Lang.zip
v 01212012
  • SU binary updated
  • Integrated ManU 2.1 HAVS-AXI-BFS
  • Volume stepping changed (Thanks LfcFan):
Code:
[INDENT] 5,  // STREAM_VOICE_CALL
 10,  // STREAM_SYSTEM
 7,  // STREAM_RING
 30, // STREAM_MUSIC
 10,  // STREAM_ALARM
 7,  // STREAM_NOTIFICATION
 30, // STREAM_BLUETOOTH_SCO[/INDENT]
  • ScrollingCache disabled for better app scrolling (Thanks LfcFan)
  • Duplicate Lockscreen menu items removed from InterfaceSettings
  • WallpaperPicker option removed from Long press > Wallpaper (FC's as no built in wallpapers)
  • MIUI Camera Added (Thanks Hadron)
  • Tweaked TCP/IP Stack
  • Tweaked Memory (Dirty Data Behaviour)
  • Tweaked low memory values:
Code:
FOREGROUND_APP:32, 8192
VISIBLE_APP:64, 16384
SECONDARY_SERVER:75, 19200
HIDDEN_APP:90, 23040
CONTENT_PROVIDER:100, 25600
EMPTY_APP:120, 30720
  • Languages are making a come back - compiling this week.
v 11072011
  • Ported CM7 Lockscreens (rotary, ring etc)
  • Ported CM Phone in order to make above work
  • Port of CM7 VOIP module
  • SIP over 3G
  • Implemented Expandable RAM disk for market downloads
Look under Settings>Lockscreen Extras for new CMy7 Lockscreen stuff.
Before RAM disk, /cache was bound to /data/local so small cache partition could be used. BUT you needed to keep enough free space to store the downloaded app before installation. RAM disk means this is no longer necessary. Now all but 15MB of /data can be used.
New Market Works. No more work around of "chmod 777 /cache" required
***Although extensive framework modifications have taken place, a wipe should not be necessary. However, any issues, please wipe.
Note* 11072011 is English only presently. v1.4 Language packs are NOT compatible. Do NOT try to flash these over v11072011
Also note /system/etc/init.d/95havsvdd script. This sets Manu 1.4 havs voltage to 875 for 128mhz. If you get reboots when idle, edit this value higher in steps of 25
v1.4
  • Updated SurfaceFlinger in-line with the google 2.3.5 repository
  • Smaller Latin IME keyboard (ROM under 60MB)
  • Reduced font footprint without compromising specific non-alphanumeric characters
  • New "cutting it fine" 60MB system Hboot created
i would advise support questions being kept on XDA?
only reason i say this is that if there are common issues they are all in one place and directly searchable within the same thread.
Testers are quite thin on the ground at the moment so I thought by posting here, I could get a bit more exposure and bump up the XDA thread. I told myself I wasnt going to do that, but I changed my mind ;)
ROM is running very well for me. Smooth, fast, stable (except the settings FC) and good on battery.
aye itll get overshadowed by the usual suspects just because of fame and the amount of people spamming the threads
+1 on the congrats Dan - need to get my head around custom MTD process and then give it a go.
Ha, ha Wilfred - watched the first 1 over the weekend, lmao but haven't watched second one yet so no spoilers please :eek:
I've done upto episode 7. It is great. Episode 8 aired last week in US so will be getting it shortly.
I'm running it pal, its really good, I am very impressed indeed, its smooth, fast and the battery is lasting really well, the only issue Is the fc, but I see over on xda your sorting that, well done pal. When ive done some more playing around ill let you know anything I find. Top job pal.
Well done! We knew it was just a matter of time for you to put together a small ROM.
I'm on a vacation now, but I'll be sure to test it. :)
updated V 1.1
v1.1
  • Fixed Force close on Settings.apk (statsreceiver issue)
  • Updated seek thumb in framework (see volume settings for example)
  • Created dGB custom Hboot to aid in the installation process.
***See updated installation section in post 1
MandaNick managed to port it. Ask him about it.
v1.2
  • Fixed Video recodring issue (libstagefrieght)
  • Fixed Google Nav issue (Tts)
Can I install this with the standard boot partitions and benifit from the extra space or do I need to flash custom boot partitions?
