Went to install apex thur bootstrap got format and cashe done went to install zip and its not there but if I go to astro and do a search it comes up what might have I done wrong.
it would be in download/ not downloads/...Yes I did download it to my browser but when I click on downloads it not there now but if I go to astro I find it so its in or on my phone somewhere right.
what do you mean ...not sure i understand your questionOkay got it loaded but where do you go to find apps.
oh i see ...thats adw launcher and there should be a little box in the middle that you can press to get into your app drawer,,,,if not long press on your homescreen and select custom shortcut ,,,then i believe launchers or activities and you should see one for the app drawer then you can create and once its done just press it and drag it into the launcher docWhen on the stock rom little arrow at bottom you push your drawer would come up all that is there is a star talk and browser.(
yes definately that way if things go wrong you can restore your backup also if you just dont like the theme or when you want to switch themes you have that backupIf I was to flash a theme should I do a backup first.
Installation Instructions: Please have a nandroid of your current setup in case this is not for you
Users coming from 1.3.0 may be safe to keep data and cache. If there are problems, then factory reset. - Uninstall updates to Market and Google Voice Search if they're there under Settings->Applications->Manage Applications first.
-Place file on your sdcard. Bootstrap recovery and reboot recovery
-Navigate to mounts and storage. FORMAT data, and cache
-Return to previous menu and install .zip from sd card
-Choose ApeX and install!
OR
-Place file on sdcard. Install ROM from sdcard in ROM manager. Wipe data and cache.
you will have an option upon installation to wipe in either rom manager or bootstrap,,,,,rom manager essentially is bootstrap with a nicer gui to it ,,,personally i prefer bootstrap ,,,,if you have any problems using rom manager just use bootstrapCan someone clarify. So if I have ROM Manager, I don't need to clear the data and cache through bootstrap first?
I can install through ROM manager and then wipe the data/cache and then do a factory reset?
I see, thanks so much for the quick reply!you will have an option upon installation to wipe in either rom manager or bootstrap,,,,,rom manager essentially is bootstrap with a nicer gui to it ,,,personally i prefer bootstrap ,,,,if you have any problems using rom manager just use bootstrap
I love the new transition animations and want to keep them. However, I do agree about the white text in the battery and want the outline. Any plans for a zip that just adds the outline?
Is this how you do any updates to the rom? i.e. to install Apex_V1_3_0_Goodies1.zip or the file above?
Also, do you have to rename them to update.zip?
All I've done so I flash/install the ApeX 1.3.1 (I'll never go back to stock, btw), so I'm very much a noob.![]()
I am having problems with my camera... i am getting black on the screen with camera and camcorder... nothing works that interacts with camera either, like barcode scanner, flashlights, etc... is the anyway to get the camera back? I tried to install the blurcamera.apk from the default-apps but that won't install. Just says "application not installed". Now I have no camera at all, no icons, like it's just completely gone.
This is the only problem I have had since upgrading to 1.3.1. No themes or anything else has been installed.
Any help is appreciated.
ok now that thats out of the way have you tried just a simple reboot?and you may just have to reinstall it ,,,,little stuff like that happens sometimesSystem Version:
Version.2.3.340.MB810.Verizon.US
Android Version:
2.2.1
Baseband Version:
BP_C_01.09.07P
Kernel Version:
2.6.32.9-g55626e1w30471@il93lnxdroid08 # 1
Build Number:
Apex 1.3.1
ERI Version:
5
PRL Version:
52189
I have tried reboots, reinstalls, everything I can think of... I don't want too have to sbf back and then do it all over again, that's a PITA setting everything up again.![]()
