bouchigo
Android Expert
It would be a headache, checksum won't match.
It worked for me, just did it yesterday.
I installed some black top mod last that wasn't Fab's...(tried looking for the thread last night and could not find it) night and my phone has not only slowed down, but freezes, and also FC's LPP sometimes...
How do I uninstall just the black top bar?
I got the exact opposite results. I couldn't get past 1.1GHz using stock or higher voltage. I found I'm stable using the Ultra Low Voltage 1.2GHz. 1600+ in quadrant, great battery life. 1.2GHz on medium or high voltage resulted in a turtle every time.
Flash your backup?
Forgot to make one, I was so tired last night I forgot, but I fixed it by just DLing Fabs Nex theme. Which looks sexy and I love the font.![]()
Quick (and probably stupid question) about this ROM and the Tranq launcher. Why is it so slow moving between screens and opening the app drawer? I even set the settings for animations and such to fast in spare parts and its still slow. Is something wrong?
I use LPP which is super fast, but I'm curious about this now.
Thanks all.
Thanks all.
Bumping myself here again.
Thoughts anyone?
Mine didn't handle the ApeX OCing, I had to shut it down and install Jrummy's to get mine to take, I'm flying now.![]()
Mine didn't either and I can't get much of a stable oc even using jrummy's oc app. I might really have a dud. lol
What is Tranq launcher? Tranquilty is another ROM, I'm thinking you've got some conflicts.
Or
I'm thinking your phone isn't handling the ApeX overclock very well. Try going to terminal emulator and typing in...
su <return>
overclock -off <return>
reboot <return>
I can get to 1.2 at any voltage so far, if I go to 1.25 it starts crapping the bed.
You can also remove the tranq launcher with launcher -rm from a term window. It is all in the first few posts. Just make sure you don't uninstall LPP without putting the tranq launcher back on.After I installed this ROM, it came up stating a default launcher of Tranq Q Launcher and Moto Setup. (I assume this happens for everyone no?) I pretty much ignored it since I use LPP
As for the OC, if I run those commands, will it permanently turn off OC? If so, I may give this a shot.
Thanks for the reply!
Trooper - The overclock -off will turn off OC at boot by default for the ever awesome ApeX rom.You can also remove the tranq launcher with launcher -rm from a term window. It is all in the first few posts. Just make sure you don't uninstall LPP without putting the tranq launcher back on.
Ah, just looked at Home Switcher, I understand now. I also use LPP so I didn't even remember the Tranq Q option. So, ignore my conflict statement. But if you are using LPP, I'd make sure you have the Tranq screen cleared off, remove all widgets and Icons from Tranq Q.
Yes, this will disable OC until you turn it back on or flash a backup when it was on. To turn it back on, it's the same steps you just have to change the -off to a -on. I'd give it a shot, you can always put it back.
The setup launcher I don't think should cause any real issue. That is just the setup page but I get that as well. I just set lpp to default and went from there.
I ran tranQ launcher for all of about 10 min as I had to do a reinstall of LPP to get my gmail notifications to work again properly but I dont' recall the drawer acting that way. Did you go into spare parts and see what the animations are set to?
Turning off oc won't increase the speed probably but it should make it more stable if you were having rebooting issues.
I've turned off OC through terminal emulator with "$ overclocking -off" and am still getting random freeze/reboots.I don't think I've had any reports of the overclock not taking at all, but a very small minority that are very unstable (reboots like every 10 minutes). That being said, 10 minutes is plenty time to disable the feature in terminal emulator![]()
I've turned off OC through terminal emulator with "$ overclocking -off" and am still getting random freeze/reboots. !
Did you type su <enter> before the overclock -off ??
If you had the $ instead of # I presume you didn't. I'm not 100% sure but I think this requires super user access to be able to turn it on and off. Also it is overclock -off not overclocking -off
su <return>
reboot <return>
@Fabolous
I've noticed that if I am on the market and I receive a text through chompsms (haven't tried with other text apps) the screen will go black. Sometimes another text will kick it out of the black screen, but at other times I have to restart the phone by pulling the battery or by pushing the power button and guessing where the power off on the screen is at.
Anyone else have this happen to them?
EDIT: Just now I pushed the power button and it kicked the phone out of the black screen and it seems to be working fine now.
(especially since holding down the power button fixes it)Yes, I don't know what's causing this though. I use ChompSMS and it happens once every few days.
Could it be because of the pop up? Are you using that by any chance?
I think it's an app issue, not really the ROM, but I'm not going to run another ROM for 3 days to see if this one issue happens(especially since holding down the power button fixes it)
