PlayfulGod
Extreme Android User
ASeventy
DISCLAIMER: This is a MODDED' ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Here ya go folks, heres ASeventy, a modded stock ROM for the Micromax A70, rooted, deodexed, and tweaked.
Added features:
Changelog
Enjoy!!
Install Notes
Links
ASeventy - Playfuldroidz Wiki
Want to Show your Appreciation?
- Author: PlayfulGod
- Current Version: 1.0
- Description: A Modded Stock A7 ROM
Added features:
- Rooted
- Deodexed
- APK's Zipaligned (better RAM utilization)
- Darktremor Apps2SD v2.7.5.2 + fix. (Class 6 or better SDCard required. SDCard needs to be partitioned for SD-EXT)
- Dalvik able to be moved to sdcard
- Nano added
- Bash added
- custom bootanimation
- No Ads Host file
- Bloatware will need to be Removed manually with Root Explorer.
Changelog
- initial Release
- 08262011
- remove added tethering app, should fix wifi issue
- added no ads host file
- added Android Propaganda bootanimation
Enjoy!!
Install Notes
- Install in CWM like any other ROM.
- Boot into CWM
- Wipe Data/Factory reset - this may be able to be skipped, but for best results it is recommended.
- goto Advanced > wipe Dalvik Cache
- Main Menu
- Install Zip from SDCard
- Select the Modded A70 zip
- When it finishes reboot system
Links
- Donate
- Any and All donations are appreciated: Official Donate link
) or CM7 to Micromax A70...
