Root [ROM]{BETA.#3} Unofficial CyanogenMod 10
chevanlol360
Android Expert
If you don't know what CyanogenMod is, well that sucks for you.​
Disclaimer: YOUR WARRANTY IS NOW VOID I am NOT responsible for any Physical or Software damage you cause to your device. If you are not familiar with anything below, I'd suggest that you do some research elsewhere to better understand before you attempt anything on your device.
Attention:
This Project is in a BETA stage meaning it has many things broken and is not suitable for a daily ROM
Latest Version: 4.12.14
Developer(s): Chevanlol360 & 985hPaKicK
Status: Beta
People To Thank
● CyanogenMod- For this a$$ kicking ROM
● 985hPaKicK- For Sharing his Device Tree with the LTE2
● Djrbliss- Loki
● Playfulgod- CWM Recovery
Whats Working??
● Well it boots lol
● External Sdcard is readable
● Audio
● Wifi
● Vibration
● Rotation
● ril partially working= calling works *will connect to 1x and 3G when it wants to*
● SMS
● GPS
● ADB
Whats Not Working??
● Basically everything not in the working list so camera, bluetooth, mms, 4G etc...
Known Issues:
● Might sometimes reboot into a screen called "HW Reset Was Detected" just pull battery and reboot.
Change log data
Code:
[B][SIZE="2"][U]Version & Date 4.13.2014[/U][/SIZE][/B]
[B]■ Fixed ril, gps, SMS
[/B]
__________________________________________________
[SIZE="2"][U]Version & Date 4.06.2014[/U][/SIZE]
[B]■ Fixed Audio and Wifi
[/B]
[SIZE="2"][U]Version & Date 4.05.2014[/U][/SIZE]
[B]■ Initial Release[/B]
Installation:
● Download zip to your sdcard
● Boot into CWM
● Great time to make a backup so DO IT
● Wipe data & cache *Required*
● Install the ROM
● Reboot
Downloads:
Latest Builds:
● cm-10-20140412-UNOFFICIAL-fx1.zip
MD5:
4ad3b02b213b34c379400aa1796dc11a​
Help Me Keep CyanogenMod Going
will otg be something beign worked on id rather use my 360 controle via usb since I cant get any bluetooth ones to work
Thanks guys, its been a very productive weekend, just got done fixing ril, ril means service so now you can make calls and send text. mms is still broken but thats an easy fix and not too sure if 3g/4g is working, i get 1x data though lol. will upload this new build tomorrow.
Then its on to fixing camera and when i get that working i'll compile cm 10.2;)
In the description it tell you, this is still a Beta it's still not ready for be used so no network no calling not text..
i read the OP, but chevan says I can make calls and text so I don't know. ↓
Hey Chev, any eta on a stable build? I will be migrating from your simplicity ROM to this one. Thanks.
rule number 1, NEVER ask for ETA's. I do this on my own time, whenever i have time.
please port for LG F260S , thanks...!
Get me in contact with the dev that ported cm10 to the f260s, i believe there is a beta for that version of the phone as well? ported from the f160 phone? get me in contact with the dev that ported it to the f260s already and maybe i'll build from source for the f260.
The key sentence is highlighted above, haven't had time to upload anything recently.
