Root [ROM][BETA][4.1.2]"L" Warp port
I know my ways around a ROM in most of the files so just let me know what to download and if it does boot what I have to do to get you the necessary files and send them to you,I thank you so much for doing this hopefully I can help you out in some way
Great!! Everything boots and works . changed DPI to 300 and lost the themed pulldown notification bar. Not the setting or slider though and 3g icon is blue sometimes . other than that works great. The pulldown menu just looks stock but tibtef status bar and everything else works great.
Kool :) does 4g work?? What about boot anim?? Can u make and recieve calls?? Etc...
I used all the frame and apps from the awe so i expected some issues... May need to use warp phone apk to get 4g
Yeah barely any bus for what it is. Thanks looking forward to it and running it as is right now on smiths oc kernel . seems smooth in throttled though so can't tell fully
Not sure if u got my pm?? When u get a chance hit me up on hangouts its much faster communication "brittnearl@gmail.com"
The theming should b just a matter of resizing images from hdpi to xhdpi... Im assuming no fc besides hangouts on first boot?? Camera and everything functions with the exception of 4g?? I want to get as much info as possible as im flying blind without a test device lol
OK sorry got it working. When switching back to 3g I hit the wrong thing . so just resizing really needs to be done. Everythings working great .love the 3minit mod.. Wonder when someone will notice a new Roms here lol. I changed DPI downloaded cmda gsm lte switch and everything's perfect now. *oh and the boot ani. Works also*
I think it'll be a couple days before people check in and see there's a rom even being worked on for this phone. It pretty much died out ..a lot of people gave up.i would change the original post saying it boots up and you just got to work on resizing images and final bugs(small) So no ones afraid to try it.
Great Job! Its working pretty smoothly on my phone- There were a few problems/conflicts with gravitybox in the status bar but other than that... yep GREAT JOB!!! Thank you!!:):):D:D:D:D
:smokingsomb::smokingsomb::smokingsomb:
I know what the 4g issue is its the phone.apk i will theme it to match next release:)
Edit: everything else seem good so far besides theming??
For anyone using tint status bar goto the last to settings in the app which is color filter change both from multiply to srcatop and your 4g and 3g signal bars will be white L style..
Still running great no issues and I'm using it as a daily
