GirLuvsDroid
Android Expert
Hey guys,
I just bought a used Droid with Bugless Beast already installed.
When I go to BB Toolkit it says I have Rom version V0.4(FROYO)
Is this the latest?
Also, i am having issues sending MMS messages. I used to have a rooted Eris, and i know this was a problem on several roms.
Does anyone know a fix for this?
Yes, you have the latest version. Do you have Root Explorer (if not, I highly recommend it)? Take a look in /system/app and see if Mms.apk is in there. If not, that's probably the issue and it needs to be put back. If your predecessor removed it using a BB script, then you can go into Bugless Beast Toolkit>Script Helper>mms and touch the button that has mms -cp. If that doesn't work, please report back and we can help you get it done.
Just kidding. Maybe I'll test your suggestion with my Droid. I've had most of Pete's roms on my Droid but I believe the first time he implemented his Auto CPU, I had issues with heat and battery life. I never thought to try it again after that.
