noseph
Which one of these is the GB file? They're not labeled like they used to be.
Check out the second page.
+1Cyanogenmod 11? please
This is the first time I have installed a new ROM and I am running into some problems. I have gotten through everything up to the point where I attempt to install the new ROM using ROM Manager. I have the ROM's zip file on my SD card and am able to select it in the ROM Manager. I then also select "Wipe Data and Cache" then "Reboot and Install" but reboot is very quick and I still have GB. Am I missing something simple?
Can anyone confirm if the current baseband_v9.zip file actually works? I suspect maybe the file has been corrupted on the box.com servers, or that the file is for a completely different device.
I just compared the baseband_v9.zip on my box.net share with the one from stcarlso and they both have the same md5 checksum value (1eac6c43055d64f8b346237ae3228626) and size (22.5 MB).
I copied the framework jars and some system apps from a cm10.1 msm8660 build to my lucid's cm10 system folder, it showed the bootanimation. But it never got past the bootanimation, doing an ADB log shows something about audio hardware or audio_flinger failed.yea, cm-10.1/4.2.2 requires a couple additions to the boardconfig and looks to need some gfx fixes done, maybe dome flags that can be used, but I;ve not investigated yet. The build I compiled booted on the connect but no display, but adb worked flawlessly.
Also, are you building CM10 from source or cooking it?? Dont see a repo for the lucid in your github.
I noticed blue lines too, but only for at most 1/10 of a second, not an ENTIRE second.Little bug
When switching apps in multi tasking,screen flashes blue for a second
Is a build server for using if I don't want/can't use my computer to build it?First let me say congratulations this is outstanding work!
The graphics for 4.2 require some kernel driver updates and so does Bluetooth. If your kernel source is forked from iproj just merge and then fix up the lge tree. Otherwise you'll need to diff and patch.
@stcarlso: If you need a build server pm me.
Open terminal emulator, type "su" then press enter, type "cd /sys/class/leds/button-backlight" and press enter, type "echo 0>brightness" and press enter. Your lights should be off.Has anyone found a way to toggle the hardware key lights? In stock ICS, we were able to turn them off completely or have the light stay on longer. I haven't been able to find settings in CM10 rom.
By the way, this rom is awesome. Thank you for all of your hard work towards it.
This phone is not Junk! If my Samsung Fascinate (which I use as mp3 player) with CyanogenMod 10.1(Android 4.2.2) and Devil Kernel is awesome, and it is just a single core, And my lucid is a dual core, then this phone is really awesome. If someone wanted to go low level and make their own drivers, then this phone would be even better.Well, being that Cyanogenmod 10 for this phone is very buggy due to using ICS driver blobs for the adreno 220 chipset. Its rather dated and I highly doubt anyone has KitKat blobs for this chipset. This phone has issues with the charge drivers also in Cyanogen10. So these issues would be worse or non functioning in anything newer than ICS. Im sorry, this phone is junk. Its using earlier hardware exclusively for GB and ICS. The devs that designed this phone knew they would have issues getting the hardware to function in ICS and after updating knew that JB would be impossible and moved on to the lucid 2 and now LG's latest hardware. Im sure the snapdragon S3 chipset thats in this phone can more than handle Cyanogenmod 11 especially with 1gb of ram but using old dated drivers wont be possible. I really hope someone could rework the blobs and maybe find adreno 220 graphics drivers for KitKat and see if it would work. Again, none of this would be stable enough to make it a daily driver. Stock ICS is neck and neck with this rom but with its issues and lack of features the stock ICS had makes it a toss up. Im stuck with this because FastBoot is no longer functioning on my phone after updating the recovery. I cannot use the LG tools app to revert back to stock on here. I also have been running Cyanogenmod 10 on here for months and playing FFIV and heavy 3d intense games for hours with no issues. The charge reboot and the occasional sleep of death is annoying but they dont happen enough to bother. I really hope theres still support for this dying device because it has nice hardware and a lot of potential. Its like running windows vista drivers in windows 8. It may work partially but expect crashes and unstable operation. Windows XP drivers wont work in windows 8. So dont expect GB, ICS driver blobs to work in KitKat based releases.
404 errorTry this standalone kernel and see if you get a picture or an error message (make a nandroid in case it bootloops, flash it over an A2 rom, wipe cache just to be safe). If nothing happens again, could you reboot and pull a log (dmesg and logcat) 5 seconds after plugging in the mhl adapter? I think it's something small that I missed in the config or display driver port.
The only changes in this kernel pertain to MHL, no benefit to flashing it if you aren't testing MHL.
