gamerkcw123
Never-mind I got it working.
I hope to incorporate a similar change to the 10.1 ROM once I fix the issues with the display. There are still major problems with the 10.1 Lucid ROM as the KGSL drivers and kernel in the LG Spectrum source do not appear to work with each other. Therefore, there is no display as the two do not understand each others' messages. Due to work it has been very slow going.
Rom works perfectly!
Any chance of CM11?
I track LG Spectrum VS920 releases with this ROM as much as possible. The Spectrum just released CM11 on 11/26 but it is still not stable.
I think getting CM10.1 running is first priority, then maybe looking at CM10.2 (Android 4.3). CM11 is probably a long way off; does it have different system requirements than 10.x? It may not perform well on the aging Lucid HW.
If the OG Nexus One can take kitkat
KitKat arrives on Nexus One via feeble custom ROM
im pretty sure the lucid can too!
I want a rom for my Lg-p509V10l
Any progress on the Lucid. I'm getting my moms old Spectrum in February when she upgrades but I'll still read this forum to keep the Lucid updated. And I've been having some problems when I lock the phone. It shuts itself off. Any ideas?
I had a similar issue with the signal falling out with gray bars. Try reflashing just the radio (check the md5 checksum first! ). That worked wonders for me.
I have sometimes fixed this issue with Settings > Mobile networks > More... > Network mode and set it to LTE / CDMA / EvDo.
Did anyone else lose internal storage space after installing this mod? On an nearly fresh instal it shows I only have 1.52GB of space.![]()
