[ROM][BETA] CyanogenMod 10 for the LG Lucid
Can someone answer this question?
What is responsible for showing the storage types in System Settings>Storage?
"Internal storage"
is always /data space. "SD card" checks /sdcard which on this build is the external SD.
I can get the storage to swap. Media scanner will not check /storage/sdcard1. Any suggestions on a fix?
The stock rom added a symlink on the internal storage to the SD card to fix the media scanner. This might work on CM as well if a symlink was made from the external SD to /storage/sdcard1. I have something working using "mount -o bind" that I will try to push out soon.
"Internal storage"
I did study the vold.fstab file from the stock rom.
dev_mount sdcard /mnt/sdcard auto /devices/platform/msm_sdcc.1/mmc_host/mmc0
dev_mount extsdcard /mnt/sdcard/_ExternalSD auto /devices/platform/msm_sdcc.3/mmc_host/mmc2
I tried to do something like this but was running into problems
I also used the symlink as well. when I tried to turn on USB connect, it would not mount on my computer. The hang could be because the mount -o bind is not in the init.rc. I could be wrong though.
There are a few tweaks I would like to play with in init.rc. The only problem I am running in to is rebuilding the boot.img. I am using mkbootimg to rebuild the boot.img. every time I push it back to the phone, it gets stuck in a boot loader loop. any suggestions to troubleshoot this. These are the commands I am using to rebuild the boot.img
find .|cpio -o -H newc |gzip > ../initramfs.cpio.gz then I use
mkbootimg --kernel kernel.gz --ramdisk initramfs.cpio.gz --base 0x40200000 --cmdline 'console=ttyDCC0,115200,n8 androidboot.hardware=iproj' -o new_boot.img I use CWM to push the boot image back to the phone.
To check to make sure it is not the changes I made to the init.rc, I extracted the ramdisk and kernel from the image. Then, I rebuild the boot image and push it back to the phone. still gets stuck in boot loop. is there something in the mkbootimg command I am doing wrong? I did the same with my tablet and it is working fine with the lines I added to the init.rc.
I just checked the script which the CM source tree uses to put together ram disks, and I have a Load Address (base) of 0x40208000 instead of 0x40200000. Maybe changing this address will fix it.
im having problems with downloading from the internet on wifi or mobile data but i can use the market with out problem ive already cleared both wipe cache and partition which didnt fix it what could be the problem i also switch between the browser in cm10 and chrome both had same problem
A logcat may be useful in diagnosis of your problem.
I had a weird bug, the other day.
I tried to call my Father and the Hospital, and I got an error.
I think it said 'Call dropped.' or something that it wasn't going through.
If anyone gets the issue, it's easily fixed.
Just reflash the Baseband. I was on ZV9, so I reflashed that one and rebooted.
The only thing I did to the phone was make a few backups and cleared the MD5 sum.
Guessing that was just a random bug, no matter reflashing the baseband fixes it!
One more question:
If I use this app and make a CWM backup on ICS, and restore the backup while on CM10 B4; will it unlock the bootloader or damage the device?
Just a thought, I am really not sure; and don't want to try it.
One more question:
I do not believe that this will work. I believe that the ICS ROM checks the bootloader to ensure that the unlocked gingerbread bootloader is not being used. It is fixable, but it may be better to restore just the data instead.
I have lg lucid I root it and download cm10 latest but not Delta.on I can call in network is says network Delta status disconnected. pls help
Interesting.
One more thing, I got a PM on YouTube for my CM10 videos.
First off, it works on the Exceed.
This is the PM: " Hi I was wondering if you could help me out regarding the lg lucid mod. I used your guide and as you know it works on my lg Verizon optimus exceed, but I am missing a lot of internal storage. I think originally the exceed has 8(?) gb of internal storage (more like 5 gb because of the system partition taking it) and with the rom, it only has 2 gb because it was meant for the Lucid and not the exceed. Is there anyway to fix this? Please advise, thank you for your time " - sonicisback
I wasn't really sure what to answer, any ideas?
I finally got the Lucid rooted and flashed etc. I really enjoyed the first 20 minutes or so of this awesome rom. Everything was working perfectly until i made a test call. I can hear the other side but they cant hear me... Seems not to transmit the audio. Voice search and such works so i know its not the mic.
I will include this catlog even though im not quite sure if i did it up to yalls liking. I really hope we can get this fixed as im really excited about cyanogenmod...
Oh and I am on B4 with baseband Zv9
Thanks in advance
Marcus
I'm starting to hate this ROM, it run smooth for 1 week, after the week I get 4-5 freezes per day:( and issues with headphones :( I wiped cache and dalvik and the problem persist
I did not run in to freezes very often. Getting stuck at the boot animation is still a problem. If I had any freezes, it happens after clearing cache on some system apps. The sleep of death is still there when charging the phone while turned off.
Okay, the ZV9 and/or B4 ROM has a huge issue.
The calls don't work, until you REFLASH the ZV9 baseband.
I may go back to ZV8, and see if the issue is fixed.
If the phone is charged while off, the phone will not respond to power on until the charger is unplugged.
Getting stuck at boot is a race condition between the LG RIL and the modem, exacerbated by CM10's faster boot time and higher clocks. A sleep statement during boot might work, but I'm not sure where to put it. What does work is airplane mode before shutdown.
I just upgraded my Lucid to the CM10 beta and everything about it is perfect, EXCEPT the GPS.
I'm going to be really depressed if I have to go back to rooted ICS because I cant get the GPS working. Can anybody give me some tips?
Here's what it does right now. If I open up maps it will prompt me to turn GPS on, so I say yes and turn it on, go back to maps. Hit the locate button and it says waiting for sattelite, even though it's got a pretty close lock on where I am.
Now, in the location settings if I hit "GPS Source" it gives me two options. "Internal" and "some hash looking set of numbers". Both do the same thing if I try to use Maps. I've tried downloading "GPS Test" and deleting the AGPS data and re-doing it or whatever, it didnt make any difference in maps. The weird thing to me, is that when I turn the GPS on, whichever source is chosen, the GPS locate icon doesn't show up at the top in the notifications area like normal.
So if anybody knows how to fix this, i'd seriously appreciate the input.
Thanks!
Thanks!
You may need to get a GPS lock on gingerbread before flashing CM10.
Really?
Does that initial GPS lock in GB somehow get stored through the multiple factory wipes that take place during the process to flash cm10?
