[ROM][BETA] CyanogenMod 10 for the LG Lucid
I was at the local bar where there is a network extender. I was getting a full signal. I guess it depends on where the extender is located in the building.
I've been having major issues, lately.
I downgraded to B3, and tried to use the ZV8 baseband.
The 'Call has been lost.' bug is STILL there.
Calls work in my house normally, it HAS to be B4 and the ZV9 baseband.
Therefore, I will reflash it to GB again.
Then, flash CM10-B3, GApps, and the ZV8 Baseband in CWM.
Hopefully, this will fix my issue.
Is anyone else having this issue?
EDIT: I downgraded successfully. It still has the issue, but reflashing the Baseband always works.
I should try upgrading to B4 and the ZV9 baseband and see the result. It will most likely be the SAME issue. I need permanent fix. I do have backups in case of any issues.
Seriously, any suggestions?
The 'Call has been lost' bug is STILL there.
The first day or 2, my screen would not wake up during a call. I have not had any other issues with making or receiving calls.
Make sure that your cache and dalvik cache are wiped. Do not for get to factory reset as well.
I know all of that. I can get the ROM working perfectly at first. It's not the wake or whatever. It's that the call won't get made, since the 'Call has been lost.' bug. It's strange.
That is strange. have you tried a different dialler APP. under about phone and status, what is your signal strength and Mobile Network Type? The phone knows it's phone number and everything right?.
No I have not, and it's perfectly fine.
I can send text messages fine.
The network settings seem okay.
I could try to tweak them, later.
Yesterday the bug happened, I tried to call again and it went through.
Is it possible that this ROM is going to be updated to A4.4 (KitKat) ?
I'd say: most likely not.
While CyanogenMod 11 seems to be released (I could be wrong, I just Google'd it and saw a beta for something) stcarlso would most likely need to start over on his work here. It's a brand new OS, and it seems like he'd need to start over. I'm no developer, and could be wrong. However, if for the most part he'd need to start over I don't blame him for not doing it.
Even so, won't the Lucid's slower hardware cause it to lag? I understand it's CyanogenMod and isn't the horrible stock ROM, but won't it cause it to lag? I definitely know some of the features in the AOKP ROMs would cause this device to lag.
Either way, just let stcarlso work on this one. He still has a few bugs to go, and hasn't fixed them yet.
We all know he is working hard (when he is not busy, with other things in his life) to fix them and get this ROM working as best as possible.
Wiped all partitions and reflashed Rom, I'm still having issues with headphones. When I plug it to my lucid it sometimes don't sound and sometimes causes reboots
I have a set of in-ear-headphones that have the mic on them. I never had a problem with them. It could be the headphones that you are using.
Strange, I've used headphones no problem.
A pair of Sony ones, and the Apple Earpods (for the iPhone/iPod 5) headphones.
Only the pause/play button works, and the speaker does not.
That could be due to it being for iOS, who knows or cares? I only use it for Music.
What kind of headphones?
What's the Music Player? I use PowerAMP, it's not free.
I bought mine from radio-shack. I use Spotify and Play-Music. Even the mic on them works just fine Try different pairs of headphones to see if it is the ROM or the headphones.
Apple and Sony headphones work fine, for me.
It's strange, it could by his headphones.
He should try it in a friends' MP3 Player, or even another Android device.
My headphones works fine in stock ICS and my sister gs3 , the problem is cm10 . I don't know why when I plug my headphones on cm10 it causes random reboots or not sound
That is so strange.
Only two thinks I can think of doing:
1) Restore an old backup, if any from CM10.
2) (This is what I'd do) Reflash Gingerbread, and then go through all of the steps and flash to CM10 B4 (Plus the GApps and ZV9 Baseband).
