Root [ROM][BOOST/SPRINT][ZVC]Marky Beats v2 beta[updated 7/30]
what are you using that app for?? i had similar issues when installing missed message flasher. I dont recommend using that and similar apps. especially when many features of apps you can do to your phone manually w/o risk
I use missed message flasher with no problems. Just wanted something where I can edit the reminder intervals. Seems like I have no stock app for missed call alerts, and I don't think GO SMS reminds me.
Is there any way to get the front led to work or is it not really there and I'm being delusional?
Sent from my LG-LG855 using Tapatalk
Isn't that the proximity sensor? That's where mine is located, to the left of the front-facing camera.
Ok so now Google play Store is giving me that error again :\ . I didn't install Light Flow this time... I do have Missed Message Flasher, but it was working with it installed.. I will do a factory reset again and not install that app.. and see what happens.. Any ideas of what apps could cause this and why it would happen days after?
*Edit: After the 5th Factory Reset, I made sure not to include any message reminder or led type apps in my restore and I am getting the error again.. I am not sure what could be causing this.. any ideas?* :(
(Note: For some odd reason I notice I can install Skype but, that seems to be the only app. I don't use Skype just started trying random apps and saw it would download this app. I also want to say that TryingToRoot's idea does work to reset Google Play Music. If I force stop and 'clear data' to: Download Manager / Google Services Framework / Google Play Store then reboot It will be like using Google Play Store for the first time. And I can use it again w/o Factory Reset, which is good news lol. I will let you know if I see the error again..)
(Note: For some odd reason I notice I can install Skype but, that seems to be the only app. I don't use Skype just started trying random apps and saw it would download this app.)
are you letting market update itself or are you restoring it from titanium??
I believe they are both the same version.. (The version that comes in your custom ROM, the backup I have are same since I did a backup of it from a fresh reset. And they are both the most current Market Version i believe.) I do let titanium restore all apps + sys data after the reset, so maybe its from that?
I think that's your problem right there. And my market on the rom isn't the newest it's the one that comes stock
Hmm, Yeah if that is the case I should be ok now. If not I will re-flash your ROM and won't restore Google Play Music and let it update. Is the one with your ROM still Android Market or Google Play Store?
its only android market. once you sign into google account. open market, hit accept. let it sit for a couple minutes and open market again and it will say upgrading to play store and you will have to hit a button
Will do if I need to.. I think I will be ok now that I did the force close and cleared the data for those three things.
Well I noticed today I wasn't able to open GMail app because it would force close. So i used Titanium Backup to restore the app + data. Which while that was happening I got a Force Close error for Google Play store. Afterwards GMail app works fine but, couldn't open Google Play Store due to Force Close. So I used Titanium backup again to restore Google Play Store app + data. I can now open Google Play Store but, Cannot download anything. I get an "Error: Error Processing purchase." Anyone else with this issue and or any fixes? I may just ty a factory reset and start again..
*EDIT: I did a factory reset and they both worked fine. (Not quite sure what could have caused this though.) <-- Well seems it was Light Flow App that is the issue. Everything was fine until I installed that again and now I am getting the same error again.*
same ting happened to me last night lol i did the same thing that u did and a backup incase it happenes again i can just restore everything
i let the market update to google play and the same issue is still happining with me idk whats going on and also i cant figure out why the led wont flash when i get notifications it only work when i take pics
I have been getting "Your Device isn't compatible with this version" messages at the top of a lot of apps in the google play store lately. I can't really remember if I had any of these apps before the rom but it seems kinda strange. Even Pandora radio and espn scorecenter say this and im pretty sure those apps would work on any phone. Any ideas?
