Root [ROM][CM11][4.4.4][FOR][Exhibit][T599x]
dadcup
Android Expert
#include /* * Your warranty is now void. * * I am not responsible for bricked devices, dead SD cards, * thermonuclear war, or you getting fired because the alarm app failed. Please * do some research if you have any concerns about features included in this ROM * before flashing it! YOU are choosing to make these modifications, and if * you point the finger at me for messing up your device, I will laugh at you. */
INFO: about cm11 ROM if you don't know About the project | CyanogenMod
Instructions
  1. Download CM11 4.4.4, Philz Touch Recovery, GAPPS,Place CM11 4.4.4, GAPPS,on your external sd card.
  2. Flash Philz Touch Recovery via ODIN. Turn off your phone, and put your phone in download mode by pressing volume down button, home button and the power button simultaneously and letting go. Press volume up when prompted.
  3. Plug in your phone via usb, and open up ODIN and load the recovery in PDA and flash away. Do not tick or untick anything.rom After it flashed, reboot to recovery (by pressing volume up, home, and power simultaneously).
  4. Make a full backup in case things go Bad.
  5. Do a factory reset or selec clean to install new rom.
  6. Install CM11 4.4.4, GAPPS, via recovery.
  7. Reboot to system, and enjoy CM11 4.4.4!:rolleyes::D
WORKING
  1. WiFi
  2. Bluetooth
  3. ADB/MTP
  4. RIL
  5. MMS
  6. GPS
  7. Audio
  8. Camera/Camcorder
  9. Reboot
  10. Video
Issues in the Rom:
  1. Screen Recorder
  2. Yet to be determined
File
New link cm11 4.4.4 : http://www.mediafire.com/download/wy2uj9yiypfsiy9/cm-11-20140921-UNOFFICIAL-codinalte.zip
New link gapps 4.4.4 : http://www.mediafire.com/download/7kd5j3mmbi69dba/pa_gapps-modular-mini-4.4.4-20140620-signed.zip
Philz Touch recovery update v6.55 : http://www.mediafire.com/download/lhj8lnfiw6cb78c/recoveryphilztouch2.zip
Note: if don't work when you try to flash philz touch please delete number 2 from recovery so it should be recovey not recovery2
odin : https://www.dropbox.com/s/9avgae6v7qrnrqc/odin.zip?dl=0
All Credit go to the guys of xda forums Thanks Gracias :D
Credit :
If you like this hit thanks :)
make Netflix work in this rom:
now just install the app sign in account run the app and then if crash is ok reboot your phone and try again for this to work don't update the app in the Google just use this app all the time Netflix v3.1.1 build 1112 - Download - 4shared
If it work for you give credit here I think [Xposed][HACK] Workaround for Netflix on CM10.1 - All Exynos4 devices - Page 7 - xda-developers
Changelog:
05/04/14
  1. Codinalte parts app (Thanks to Meticulus!)
  2. Added Netflix fix in the rom now you just need to install the app only
  3. Ported low in-call volume fix from TeamCanjica
  4. Added Blinking BLN support ( When you get a notification and the screen is off, BLN blinks until you turn the screen on)
05/10/14
  • CM sources update
  • display libraries built fully from source using NovaTP GCC 4.9
  • display: libgralloc
  • display: libcopybit
  • new CM theme engine
    OK Google fix too now you say ok Google and it work
06/18/14
  • CM sources update to 4.4.3
06/20/14
  • CM sources update to 4.4.4
08/02/14
CM sources update to 4.4.4 r2
09/18/14
Add the app to sdcard now in the rom
Youtube still dont work next build I guess
09/21/14
new fix for youtube now work thanks to meticulus
Don't work. I get error this package is for "codinalte" devices: this is a "codinatmo"
Instructions
  1. Download CM11 4.4.2, Philz Touch Recovery, GAPPS,Place CM11 4.4.2, GAPPS,on your external sd card.
  4. After it flashed, reboot to recovery (by pressing volume up, home, and power simultaneously).
  5. Make a full backup in case things go Bad.
  6. Do a factory reset or selec clean to install new rom.
  7. Install CM11 4.4.2, GAPPS, via recovery.
  8. Reboot to system, and enjoy CM11 4.4.2!:rolleyes::D
WORKING
  1. WiFi
  2. Bluetooth
  3. ADB/MTP
  4. RIL
  5. MMS
  6. GPS
  7. Audio
  8. Camera/Camcorder
  9. Reboot
  10. Carrier Names
  11. Video
File
CM11 :cm-11-20140411-UNOFFICIAL-codinalte - Download - 4shared - Jose Figueroa
Philz Touch recovery :recovery.tar - Download - 4shared - Jose Figueroa
gapps :pa_gapps-modular-mini-4.4.2-20140321a-signed - Download - 4shared - Jose Figueroa
odin :odin - Download - 4shared - Jose Figueroa
Credit :
To me all work fine if you find something let me know or pm me
Hmm I'll ask you since you're already on but i flash vanir rom and for some reason my data is messed up. You know any way to set data settings back to stock or something?
Dadcup. do you Know how to compile a kernal? I want to see if we can add kernal support for this rom for Inline call recording using "call recorder" by Skvalex. You can find it on XDA.
Hey I am working but I have weekend off and yes i know just pm in Friday ok
i like the rom but unfortunately if i cant record calls i wont be able to use it. I need the ability to record calls for my business. good work though.
by the way Dadcup, check your pm
Hey just wondering if anyone know how to get netflix working I cannot et it to work on any 4.4.2 rom even using xposed workaround any ideas would be great
OK I want to shared a features in cm11 just go in build number and tap like three times and USB debugging will be on so then go back and hit developed option there is some features lol
