I still need a netflix fix I have tried xposed netflix fix. The netflix persist hack and novafusions fix and none work
OK I need test for this file fix for Netflix someone can test here http://www.4shared.com/zip/fRnL4k1Mce/netflix_files_temp.html
and this too http://www.4shared.com/mobile/W2gCm5Ylba/Netflix_v311_build_1112.html
First install the temp files with recovery and then install old Netflix app from your sdcard lol any one the test this let me know
If it work for you give credit here I think http://forum.xda-developers.com/showthread.php?p=44620661
OK so I flashed the file via recovery and then installed the provided Netflix apk and I still get a force close after selecting my profile
Try to reboot after install the app
OK tried it again with reboot and it is still force closing in the same spot. I don't know if this helps but the fix that gets the closest to working is the xposed workaround it will get to where you click on the show and freeze with a blank screen and the play bar in the bottom
Sweet I got it to work I used the fix you gave along with the xposed Netflix workaround and the apk you gave
Weird I couldn't get it to work without it
Because if you have the new version install before it do that you need to install uninstall a few time to get to work try without the xposed and let me know
I removed the xposed module and it stopped working and re-added and it started working again
is this build based on the cyanogon 11 M6 they released recently?
Hey thanks! This phone was a mess, but your ROM fixed it.
Is anyone else having issues with switching apps to SD card?
