Root [Rom][Custom-M050] XE ULTIMATE 2014.6.14 Work~
okJys
- NEW -
coming soon~
72108d1402673903-rom-custom-m050-xe-ultimate-2014-6-14-work-screenshot_2014-06-14-00-28-07.jpg
- OLD -
Stock ROM
C811-M050_Global_Stock_Rom 2014. 5. 20 AM00:49 LATEST Update Work!
GzOne Rooting by CA201L Bootloader(VolumeUP+PowerON)
CWM Recovery by CA201L Bootloader(VolumeUP+PowerON)
*Mod Removed*2014. 5. 20 AM00:30 LATEST Update Work!
*Mod Removed*2014. 5. 20 AM00:27 LATEST Update Work!
CAUTION!!!
1. Install after Working Changed CA201L Bootloader!!!
2. Install after Working Changed CWM Recovery!!!
VBO
[Rom] VBO
[Rom] VBO
These titles sound extremely over-commercialized :D
I find it strange that you can't do factory reset. Every ROM should support it. What if you do reset? Will it stop working? If yes - that sounds kinda extremely unstable.
Anyway, I'm fine with stock, just wondering...
Factory Reset:
Flashing Stock Rom - Factory Reset - reboot - Power OFF - VBO reinstall
Because,
factory reset after VBO installing.
- the camera does not work.
@Doctoror,
I installed this on a C811 and the data would not work. When I tried to boot into recovery to go back to M040 the phone bootlooped and I had to buy another one. I'm assuming that it is for the CA201-type-L specifically so l would stay away.
@Doctoror,
It's for the second time someone tried these Korean software on C811 and bricked.
Anyway, it would be more useful (and probably more safe) if you tried CA-201L aboot with M050 bootloader rather than this :D
Yeah doctoror right, make sure you can access hard key recovery, I hope only me had experienced with hard brick :p. Only JTAG solution:boxing:
No you were not the only one. I bricked a c811 with this. JTAG is not available where I am but Verizon happily sold me a new one. I still have the brick and if I ever find a way to fix it I will.
1. Reboot to CWM wipe data/factory reset, cahe, dalvik-cache. Format data, cache, system, sdcard.
Flash C811-M050 BASE.. done!
wipe cache, data/factory reset, dalvik-cache then go back
2. Flash GzONE-Rooting
3. Reboot,......test camera work!....Power off.
4. VOLUME UP + POWER..boot to CWM then flash VBO JB HARDCORE SRS....done!
5. Wipe cache then reboot.
Sound great! :thumbup:
And camera worked: :thumbup:
JTAG is not avalaible, but you can bring your running C811 and make backup and then write to your bricked phone. Someone in vietnam forum known the pinout, or image from this can help to search pin out
What is the differences between C811-M050-BASE with C811-M050_Global_Stock_Rom if only updater-script or anything else???
Oh, i see updater-scripter and apns-conf.xml are changed (so no big problem i do not need to replacement)
