Root [Rom][Custom-M050] XE ULTIMATE 2014.6.14 Work~
I did:
1. Go CWM wipe data/factory reset, cache, dalvik-cache and format data, cache, system, sdcard
- flash C811-M050_BASE
- wipe cache, dalvik- cache, data/factory reset
- reboot .... test camera ok! Power off.
2. Go CWM by combine POWER + VOLUME UP
- wipe cache, dalvik-cache
- flash VBO_EIZO 2014.5.20
- wipe cache, dalvik-cache then go back
- flash GzONE-C811-ROOTING
- wipe cache then reboot!
Everything work !!! Thank you!
:thumbup:
Jacksonville is about 60 miles from me. I can't go to that web page here at work because it is blocked. I'll look into it tomorrow. If I can unbrick it I'll probably sell it on eBay to get some of my money back that I spent replacing it.
I did with latest ver SRS, everything work except the issue still remain
Troubleshooting
If No problem Camera. Next:
1. CWM Recovery Enter.
2. Stock Rom C811-M050 Re flashing and...
3. Re flashing VBO™JB SRS Solution.zip
4. Reboot...
Not need -wipe data/factory Reset and patition cache.
I did several times never wipe data/factory reset and cache partition, I only wipe dalvik-cache after flash Stock and SRS but can not solving problem
TEST Modify Rom!
Stock Rom and full wipe Not Need!
Direct Install (Auto -wipe cache and dalvik-cache)
Install-1::D
*Mod Removed
Install-2::confused:
*Mod Removed
Next Update...
TEST Modify Rom!
Install-1::D
*Mod Removed
*Mod Removed
I use CA201 type L, hardware version 0.3
Direct install-1reboot:confused:
Direct install-2 and reboot
Fail...:what::what::what::what::what:
I understand this VBO ROM is supposed to protect the ears, and customise the sound, The speakers are louder on this hone than most any speaker i have used this size.
Whats the main application to this rom?
