NYCHitman1
Gun for Hire
About Us:
Dirty Unicorns is a project that started out with no name. It was a project that was first created based off AOKP back in the early days of Jelly Bean because of curiosity. In the early days, it was just a one man show on one device (EVO 3D). However, many others have joined the project since and it has grown a lot. We have seen a wide variety of talent contribute to this project of ours and many of our contributors have gone on to help other projects, and that is ultimately why we do what we do.
Once Jelly Bean was over, we decided in Kitkat to move to a new base, which was OmniROM. While AOKP was fun, OmniROM proved to be even more exciting because it challenged us to see what we could with something different.
With Lollipop, we have moved to an AOSP base with a lot of patches from CAF to make our older devices function as they should. With that said, it has been an awesome learning experience and it's still not over! We are still learning every day and continue to move forward.
Few more things we will say is that we don't accept nor ask for donations. We don't believe in that. Everything that is necessary to keep this project going is out of our own pocket. Gerrit, Jenkins, Websites, Devices, etc.....
All we do ask is that you search, read and try to enjoy the process with us!!
Kernel Source:
http://github.com/DirtyUnicorns/android_kernel_lge_hammerhead
Flashing Instructions:
- Verify that you're using the latest version of TWRP
- Perform a FULL WIPE as described below if coming from another ROM
(A full wipe is when you wipe system/data/cache/internal and/or sdcard)
- Flash the latest version of this ROM
- Flash recommended GAPPS linked below
- Reboot and ENJOY!!
**If you fail to follow these instructions, don't bother reporting any bugs**
**If coming from a previous lollipop version, wipe system and cache**
Change Log:
Code:
[B][U]Version 9.3[/U][/B]
- Update to Android 5.1.1
- Materialize DSPManager
- Fix SysUI FC for Themes with QS mods
- Change checkboxes to switches
- Remove Voice Dialer
- Fix for Play Services deep sleeping
- Fix various Theme Engine issues
- Add back notification LED settings backend
- Fix NavRing FC
- Expose values for our applications to be themed
- Hide lights settings if device doesn't support them
- Don't set preferred APN's automatically
- Fix battery and notification lights
- Various translations
For detailed change log, check [URL="http://gerrit.dirtyunicorns.com/#/q/status:merged,n,z"]http://gerrit.dirtyunicorns.com/#/q/status:merged,n,z[/URL]
Code:
[B][U]Version 9.2[/U][/B]
- Added DU-Updater
- Make Navring available to devices with no navbar
- Add user configurable shortcuts
- Implement ambient display as Active Display
- Change location sensors mode in quick settings
- Show carrier label / custom and change color
- Add Left clock
- Volume rocker music controls
- Double tap to sleep on navigation bar
- Navbar ring targets
- Option to show four tiles per row
- Lots of tiles added
- Theme Chooser updates
Code:
[B][U]Version 9.1[/U][/B]
- Navigation Bar Customization
- Add navigation bar arrow keys toggle
- Add left and right virtual buttons while typing
- Create expandable volume panel
- Battery and Notification Lights
- Add Sync tile
- Screenshot Tile
- Update default app icon to a more material like icon
- Material Design makeover
- Proximity speaker: add time delay preference
- Headsup Options
- Mms improvements
- Lockscreen Tile
- Lockscreen shortcut customization
- Themed DU kb hints/spacebar
- Add About DU to settings/about phone
- Add our changelog back
- Allow disabling of FC dialogs
- Update SuperSU v2.45
- Materialize volume panel in/out animation
- Power menu screenshot delay
- Theme Engine
Code:
[B][U]Version 9.0[/U][/B]
- Initial Release of Lollipop
Credit and Thanks:
We would like to give thanks to everyone that contributes to the Android community, small or big because every bit counts. Although we can't list each and every contributor within the Android community, we would like to highlight some of the teams and individuals that have made it possible NOT only with just this version of DU but throughout the years because we don't ever want to forget where we came from.
That said, on behalf of the DU team we say THANKS to....
JMZ Software
Baby Jesus
Code Aurora Forum
Omni ROM
Android Open Kang Project (AOKP)
Android Ice Cold Project (AICP)
XDA-Developers
SlimROMs
Preludedrew
Max Weninger
Team Black Out
CyanogenMod
*If we have left someone or some team out, please accept our apologies*
Download Links:
Stable (9.3) - DU_hammerhead_5.1.1_20150426-2219.v9.3-OFFICIAL.zip
Weekly - DU_Hammerhead_Weeklies
Recommended GAPPS - DU TBO Gapps || Banks Gapps
Other Links:
G+ community - https://plus.google.com/u/0/communities/109738128866939227235
ROM Source - https://github.com/DirtyUnicorns
Gerrit - http://gerrit.dirtyunicorns.com
Crowdin (translations) - https://crowdin.net/project/dirtyunicorns
Jira (Bug Report / Feature Request) - http://jira.dirtyunicorns.com/
I'll try on the pc tomorrow.
