Root [ROM] eS3eeM ms910 ZVE
D0VeR
eS3eeM ROM V2.4.ms910.ZVE
SPECIAL THANKS TO:
LDrifta
ROM base
Thanks Brutha!
Donate Link
DoVeR
(heyyyyy... that's me!
DoNaTe 2 DoVeR
Stitan
4 capturing and posting screen shots 4 you all
AND OTHER DEVELOPERS AND THEMERS MAY HAVE HAD THEIR HAND IN SOME OF THIS AND WILL RECEIVE RECOGNITION WHEN IT IS KNOWN
What is included in this package:
I don't remember. If any users get bored, please post details
BiG FAT DiscLaimeR:
Root related activities
such as flashing a custom ROM...
should only be performed by persons
who know what the hell they are doing!
If you do not know what your doing...........
Then have yourself a look at the pretty pictures real quick,
Get excited, drop a load, then navigate yourself outta here!!!!
Shoot over to "All things root", and start reading!
I myself, android Developers, Themers,
nor the Android Forums
Are Responsible if
Your Phone
Go
!BOOM!
Links:
DOWNLOAD eS3eeM ROM V2
:D:D:DDONATE:D:D:D
Installation instructions:
Wait
If you don't know how to flash a rom...
then scroll back up to my big fancy disclaimer.
Note: install script will wipe data dalvik and cache
but I suggest doing it manually anyway before install.
ISSUES / Not Working:
ics keyboard. sorry, I forgot a file
download file libjni_latinime_moded.so and paste to following directory
/system/lib/
Known annoyance:
Shake to change wallpaper can be disabled in launcher settings.
Pretty sweet, thanks DOVeR!
Anybody get the ICS keyboard to work? mine just keeps fc
Really?
Hang tight. It's one of two things
I'll find the files
Probably the lib file needed
Give me a hint
Does a red themed ics keyboard pop up real quick and then fc?
Or is it standard grey ics key?
Never even get to see keyboard, soon as I choose ICS in Input Method get process inputmethod.latin.ported has stopped unexpectedly.
Download the file and add it to system/lib/ folder. Let me know what you get.
The problem is. There is an ics keyboard a_p_k file and it needs the library file as well in order for it to run. Now what happened is I've got 2 keyboard a_p_k files 1 is stock I c s keyboard and the other is a modified keyboard I'm not sure which 1 I package in the rom
What what dammmmm that thing looking good not one but 2 thumbs up . I see thanksgiving was all about giving the esteem has been giving a new life .
Wish I had an esTeem still. There was a lot I still had planned for the es3eem including a new messenger layout, blue on black keys and tweaks n such
bloody ics keyboard
https://db.tt/A4dBHieD
download and add to system/app/
this will only work if you have already added the lib file mentioned earlier or in the op
ill package this stuff in next build
when.... I dunno
Will be testing today and what not, nice to see forums over here back up and running at least a little bit, my HTC one is beautiful but whenever i can i will be all over my esteem, i love these forums.
