Root [ROM] GingerSteem Extreme II for the LG Esteem MS910
PlayfulGod
Extreme Android User
DISCLAIMER: This is a MODDED' ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that that I am not liable for any or all consequences of using this ROM. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Here ya go folks, GingerEsteem Extreme II built from ZVC!!! It has been debloated, deodexed, and tweaked for better performance and speed.
  • Version: 1.0
  • Developer: PlayfulGod
  • Description: Modified Stock ROM for the LG Esteem M910
GingerSteem Extreme II w/ Plague Kernel What is this? This is a lightweight ROM built both for speed and stability. This ROM is based off of the LG's ZVC update to Gingerbread. It is fully deodexed, and debloated.
Changelog
  • v. .02 Initial Release
  • Based off of ZVC Gingerbread 2.3.4
  • Deodexed
  • Zipaligned
  • Debloated
  • ROM Toolbox (Free version) - overclocking/underclocking can be set with this app among many other features.
  • Custom Boot Animation w/ no sound
  • CRT Screen Shut Off
  • Battery Charging Animation
  • Plague Extreme II oc'd to 2Ghz max
  • CM7 File Manager
  • 02202012
  • Added homeless battery setting to Plague
  • added android keyboard back
  • moved ROM Toolbox to system/app (thinking maybe this will fix app installing issue)
  • SIO added to Plague
  • 03032012
  • Mt's power Options Mod added
Plague Kernel:
  • Overclocked to 2Ghz max
  • Underclock settings added as well
  • Interactive governor added
  • Smartassv2 governor added
  • LagFree governor added
  • On the fly voltage changes (Need to find an app to support his still)
  • Tun.ko support
  • CIFS support
  • SDCard Read Ahead Speed Tweak
  • SIO Scheduler
Screenshots
  • N/A
How do I install this?
  • 1.) Download the .zip & copy to phone or sdcard (make sure 4g or wifi is enabled if dl'd from phone).
  • 2.) Zip can be installed from either internal or external sd in CWM
  • 3.) MAKE A BACKUP
  • 4.) WIPE DATA!!! WIPE CACHE!!! WIPE DALVIK!!!
  • 5.) Go to install zip from sdcard
  • 6.) Select GSE-C-vx_signed.zip
  • 7.) Reboot
Downloads
*md5sum: 7ecbc324ae7c6e63c16889c26581f311
  • Also available thru ROM Manager!
http://www.youtube.com/watch?v=LT7kxjX75rg
Donations Official Donate link if you like my work and would like to show your appreciation and support. All donations are greatly appreciated!!
I take it that this version isnt themed?
updated googlequicksearch and vendor apk's, default wallpaper changed out, and umm wifi icon.
I want to add boot options but not had any luck adding em myself yet lol
I flashed KaneOfMars ICS theme yesterday n didnt see any issues while I had it on the phone.
could you add, kangwish theme based on ics.
Think I am gonna do my own thing to this one. ;) I kinda like how it looks atm. Like to get rid of the stock lockscreen, make the notification dropdown transparent and a few other things.
Just got done adding the sio scheduler and the sd read tweak to the kernel.
Still trying to find an app that does voltage control as I added it too, but it needs testing b4 I can say it actually works.
Hi pg does zvc run roms better even though u made the first one cause I want to update if zvc mite be more stable then zvb
Oh well still mite do it lol I think alot of ppl are gonna want to work with zvc so I had alot fun with zvb and if nobody really come out with stuff I know how to down grade so ill update nd flash the rom
  • Version: .02
Changelog
  • Deodexed
  • Zipaligned
  • Debloated
  • Custom Boot Animation w/it no sound
  • CM7 File Manager
Plague Kernel:
  • Smartass2 governor added
  • LagFree govnor added (Experimental)
  • Tun.ko support
  • CIFS support
Screenshots
  • N/A
  • 3.) MAKE A BACKUP
  • 6.) Select GSE-C-v.02_signed.zip
  • 7.) Reboot
Downloads
*md5sum: 03201d5f800076c8b483054e4ccffc19
Dose this work on c and b?
I've not flashed it over zvb yet but should work fine.
sorry I am a newbie....what on my phone do I need to install and upload this tomorrow? I have root explorer( but not sure how to use I yet...) or should I dl it onto the comp then phone?
Hi PG i updated n flashed ROM having trouble when downloading app from market it start when almost done downloading it reboots
first you need to dl the AIO n run it from your pc to root n install CWM. Then dl the ROM either from your pc (best way) n copy to your sdcard or dl it from your phone n then reboot to CWM n install zip from sdcard.
What is aio? My phone is rooted already
