colchiro
Extreme Android User
I decided I better bring my wife's NC back from the dead (it's sdcard was dying).
So I copied everything over to a new sdcard, brought CM7.1 up to date, backed up everything, then decided to give CM9 a try.
Did a clean install of the latest nightly and installed Nova launcher. I found the touch screen very iffy. Things like trying to add a widget to the desktop (by long-pressing) or trying to remove one by long pressing, was difficult and took several attempts, since the screen would just twitch back and forth. Also apps that worked fine with CM7 and on my Touchpad with CM9, would FC.
So I've gone back to CM7.1 and will try CM9 in a month or so.
