Root [Rom]JellyBam For Motion[Port]
Do you have PAC working? Also, how did you fix WiFi?
i edited the wpa_supplicant.conf with my wifi info but it breaks settings unless you push menu then manage apps. and you have to edit it manually anytime you want to switch to another network.
Even after editing the wifi thing, it won't connect to any network and the settings work normally
look at the attachment to see what mine looks like. of course you would have to change the ssid and password and even key_mgmt if you don't use wpa-psk
it connects automatically on mine. but it can't be changed except manually.
Still can't connect to wifi.
How would you write wpa wpa2 psk? Maybe that's the problem
Only thing stoping me from using this as daily :)
did you use capitol letters? WPA2-PSK
if you setup all the networks you use commonly it will auto connect when in range.
i don't know for sure. i know in linux you put "key_mgmt=WPA-PSK" and then you add a line "proto=WPA2" but i'm not sure if it's the same in android.
Wifi definitely has something to do with the settings apk, I've been trying to port pac all day and it has the same wifi problem. I'll try to fix and post later.
I built a pac which is about the same as this ported from optimus l7 got wifi working. I used your Jellybam as base to fix some android not responding errors I call it Pac Bam im gonna post a link. :D :cool:
Took me until 2:03 AM to make I woke up at 10 AM. 17th time's the charm I still want paranoid to change dpi individually.
I'll fix the build.prop to show correct version info later and also try to see if i can get paranoid to change app density individually.
