Lets hope! Cause the WiFi problem is pissing me off lol
Well I have good news and bad news... The good news is it compiled! The bad news is... Wireless doesn't work!
I'll get back to you in a bit.
hierarchical
Great, I'll fix that in a jiffy!
Otherwise is R4 working good for you guys?
Overclocking works awesomely, looks good so far. Haven't had alot of time to test out if everything works but great job on the OC.
Adding the new Adreno drivers helped the phone, but OC'ing helps it even more! I'm able to run TSF Shell with very little lag... Which is surprising to me.
I found out two new things for the ROM:
1) LG sucks badly when it comes to market compatibility for their devices. I can in no way get the phone to install some apps I KNOW run well on the phone (Do not show up in market, when I do find the link in market, says it's not compatible with my device). To test this, try installing Soundhound or shazam. If it works for you, must be my phone which is messed up.
2) The reason auto brightness doesn't work is because LG brilliantly destroyed the light sensor driver. Lux values returned by the phone is always -1, meaning no data is returned from the sensor... Will have to kang work from another phone to re-enable light array.
This weekend I'll actually have time to d/l 2.3.3 sources from Google and actually attempt a git-merge of V20B sources. If we can compile the framework from scratch, I will have a better time of porting over CM7 features using actual code.
I'm a much better programmer than modder haha.
Im gonna attempt to flash this to my phone after I back up all my apps >.>
I am having problem with your rom. At first I had jiilik's version and had the dalvic cash issue so I tried karendar's and would keep reebooting by it self so I went back to jiilik.
Now I amd still trying karendar but I am still having the dalvic cash just like with jiilik.
I did wipe averything "all data/factory reset" and also Data, cash sdcard/.android_secure, system, dalvic-cash each separately.
Probably overkill but better safe then sorry.
I understand that wiping /system removes it all so I reinstall the rom, do factory reset. I install a few basic apps and reboot often and after a while the dalvic cash problem just come back again.
I have the latest software v20b
- Freshly compile kernel based on v20b source with 4.4.3 toolchain (Maaaaad mad mad mad props to Jiilik, I never would have compiled my first kernel if it weren't for you)
Hey thanks! Glad to see you folks are still working on this.
I was really motivated about having your custom kernel on v20B... So I read up on how to compile kernels and let me tell you it's pretty easy to do! Now I have to figure out how to fix liblights.
Whenever I try to download something on market, the phone resprings (sorry, don't know what the android term would be) and so I can't download anything. Is that part of the play market issues you mentioned in your post? I'm still on the old market because it won't let me download or upgrade anything.
Otherwise, thanks for the amazing tweaks, the phone feels fast now.
Some more info: The kernel is the right version (says Karendar) but the software version is still at v20a.
Before upgrading the ROM, did you flash stock V20B?
Ahhh.... Now I see what's wrong, lol. The phone is still on v20a for some reason. I restored my nandroid backup and checked the settings, it's gingerbread 2.3.3 but the software version is still v20a. I thought it was v20b before I flashed anything, but I guess I was mistaken. Is that what's causing the problems?
How can I update to v20b?
