Lightswarm
I read the instructions, and how does one fix permissions? I'm quite curious before I consider unlocking my Spectrum's bootloader and rooting it. Thanks for any response!
I'd be fine with stock for now. Camera ICS is nice, but the ads are annoying. lol
do you guys all like the s3 boot animation? or should i change it? remove it?
Can I flash right to this from v6?
Ad block maybe? I use the blocker in rom toolbox.yeah the ads are terrible.....
ALL CREDITS GO TO LEGMANDO33 FOR THIS!! WITHOUT HIM THIS WOULDNT BE HERE!!! THANKS BUDDY!
Want an aosp status bar?
here- https://www.dropbox.com/s/jhx9h8tgpgaweur/AOSPStSe.zip
DONT FORGET TO WIPE CACHE AND DALVIK AFTER YOU FLASH THIS!!
Screenshot:- https://www.dropbox.com/s/dyd49zs7v113bk5/Screenshot_2012-11-04-09-42-49.png
ICS camera 4.2 FCs on launch for me also v1.1
Ditto. An old Motorola rom had the host file coded in and it made it impossible to access some sites that use ad-based redirects. Drove me mad.That's what I'm using also. I actually don't want it in the OS as I like to be able to toggle it on and off for games (sometimes).
coderaz you wiped cache and dalvik? hmmmm....
Yup. Before and after. Still FCs.
Working on it. =)
Damn you for stealing my self-pity! lolcoderaz you broke it!!![]()
OK the netfork tweak seems to not be working so delete it from the /system/etc/init.d and delete it and flash this zip with init.d tweaks that greatly improves overall performance
update.zip ::. | by needforspeed953@gmail.com for Generic Device
ALSO WIPE CACHE AND DALVIK AFTER YOU FLASH IT AND FIX PERMISSIONS
Once I have Icy Fusion installed, I can install Rom Manager right?
