Root [ROM][July14] Icy Fusion V5.0 | Smooth | Tweaked | Themed | Battery
Yeah you don't really need ROM manager and sometimes it doesn't even work so I just type in terminal 'su' then 'reboot recovery'
Azoller1 great work . I am enjoying the rom. As to reboot into revovery I us titaium backup as I all us it and don't have to download something else.
Nope forgot to do before if you didn't flash it yet you could run a benchmark? I'll run one now and see if it helped
Erm... oops. I already flashed... I can roll back my nandroid to v1.1 and do a bench and then nandroid back to v2. I'll get it to you in the morning. :)
Here is with tweak, this doesn't seem very well.....
Congrats Aroller, this ROM looks great. I have been setting up V2.0 for the past hour or so and it runs very well. Seems to charge faster too. Will come back in a week or so with results of long term test
How would I get the "circles" widget to run on a 3rd party home screen? It looks cool and I would like to use it.
You can't. That check is internal to the widget itself. You might want to look at One More Clock, however. It has similar functionality (along with tons more layouts).
Thanks for the Rom! Any recommendations on themes, apps?
That is a total open-ended question... ;)
My personal favs (all around and on this ROM):
Holo Launcher HD (Apex and Nova are ok, but I feel that Holo is still a bit faster. Personal opinion and YMMV)
AirDroid
AnTuTu Benchmark
SetCPU (Setting profiles for various states can save battery)
Chrome (Sync... enough said)
Google Drive
Messaging App from JB 4.1 (You can find this in the market now)
ROM Toolbox (for reboots and managing ad blocking)
Subsonic (for music. Even if you don't have a Subsonic server you can use, local mode will work. The EQ actually works pretty well)
Transdroid (for remote torrent management)
MetroStation (for icons. What can I say, I like the rounded icons. *shrug*)
Quick bug report: When adding a word to the user dictionary, Settings FCs. I don't have a logcat of it, but I can reproduce it every time.
Would it be possible to switch the phone app with the cm or aosp phone app? I was just curious because I like it's interface better.
yeah the ads are terrible.....
Hey-Great work. I have to say that the Razer launcher stands heads above the rest, especially the triple clock widget. Also, Google play has the Camera ICS+, with no advertising, and it is worth it. In any case, the rom is as fast and smooth as anyone could want, with a decent battery life.
will probably change the hosting site to dev-host becuase that never seems to be slow at downloading, and currently working on an update with crt animation, and some cm9 apps and tweaks and other features
Great Rom Azoller1 !! love it. The only issue i'm having is with the sound. My calls can be hard to hear. (low volume) In B.O. Rom, I remember reading that Beats Audio was causing this and was taken out.
yes i also noticed this will remove beats audio, it didnt help much either i didnt hear a difference in my music
