uploading my final version! im going to miss this rom! this is the most stable one! have not found any issues! everything works now!
I was going to recommend grabbing the email and exchange apk from CM9 as it seemed to work properly. I tried to install and replace and add those apk's in your ROM today but of course the university has to do maintenance on the exchange accounts so that I can't test if it fully works.
I don't see a link on the website.uploading my final version! im going to miss this rom! this is the most stable one! have not found any issues! everything works now!
call volume is great. Bluetooth is broken with the pwned kernel. None of the custom ROMs have bluetooth until someone comes up with a new kernel that fixes it.Can't wait to flash it. Bluetooth and call volumes fixed?
Correction: none of the stock-based custom roms have bluetooth working. CM10 bluetooth works.
The beta2 releases of Quattrimus JB have fully working bluetooth - CM10 and AOKP41. I also believe there is some conservative overclocking in there too...
1624 overclock I believe. Even without the overclock it runs fast. Going to flash this version now![]()
will probably make another final that fixes bluetooth....
I know it's not polite to ask this, but, when would that be? I've been running your ROMs, I really like them, and I've been waiting (awhile) for someone to fix bluetooth...
Sometime today
Thanks! So, I'm running your 3.5 now (was most stable for me), can I just flash your 2.0 (with fixed BT) over the top of that?
Hi! I'm new here and I'm trying to get this ROM installed. This may be silly but I use PagePlus so would I be able to flash carriers with Icy Fusion (say through flashitnow?) I know the admins there say it may not work but some of you would probably know better - thanks!
Might need to do full wipe but you don't have to and the version up right now doesn't have BT fixed yet I'm releasing a new one later today with it fixed
